Cellular Innovations HFBLU-CX1 Wireless Headset Logo
Posted on Jan 06, 2009
Passcode ive lost my owner manual and i have a new phone i need the passcode to secure connection with HFBLU10K
  • lchen Jan 08, 2009
    Yes, I have the same problem. How I can find the passcode? Thanks,-Lin
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
148
Points
Anonymous
Level 1:
  • Posted on Jan 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
148
Points
I need a passcode for my hfblu10k
It is supposed to be 0000 according to the manufacturer.
Feb 18, 2010 • Cell Phones
1helpful
I lost my passcode and now I can't connect my bluetooth
Here is a helpful link http://www.ehow.com/how_5169210_bluetooth-passcode.html
Phone passcode:
if you haven't actually manually changed it, the password is always the last four digits of your phone number (ex. 1-555-868-2212 your password is 2212). If you manually changed it, you need to call your cell phone provider and have that worked out.
-CompDoctor
Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
Hello my friend,do these steps
Pairing with another Bluetooth device
By pairing your KU990 and another device,
you can set up a passcode protected
connection. This means your pairing is
more secure.
1 Check your Bluetooth is On and Visible.
You can change your visibility in the
Settings menu.
2 Touch Paired Devices then New.
3 Your KU990 will search for devices.
When the search is completed Refresh
and Add will appear on screen.
4 Choose the device you want to pair with
and enter the passcode then touch OK.
5 Your phone will then connect to the other
device, on which you should enter the
same passcode.
6 You passcode protected Bluetooth
connection is now ready.
Using a Bluetooth headset
2 Follow the instructions that came with your
headset to place your headset in pairing
mode and pair your devices.
3 Touch Yes to Connect now. Your KU990
will automatically switch to Headset profile.
If you have any questions you can try reading the manual here
http://www.in.lge.com/Product/Manual/KU990.pdf
1helpful
Mislaid booklet
passcode for sonyericsson HCB100 is 0000 manual PDF from http://safemanuals.com/user-guide-instructions-owner-manual/
Passcode
wats the passcode for a 9xx plantronics bluethoot
4helpful
3answers
Cellular innovations HFBLU10K OWNERS MANUAL
hello all my name is lynwood i am a tech at Mizco Int'l you can email me at [email protected] if you need a manual or any help on this product. thank you and have a great holiday season.
4helpful
3answers
LG Bluetooth HBM -500 Passcode for pairing
I HAVE LOST MY Bluetooth H500 Manual, can you assist with passcode.
25helpful
5answers
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Top Cellular Innovations Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Cellular Innovations Radio Communication Expert? Answer questions, earn points and help others
