Inner bladder is needed to hold the fresh water for spray. Make sure the bladder is pulled through the bottom of the tank and that the black cap with a red rubber seal on the bottom of the tank. If the black cap is missing you'll need to purchase a new one. Here's a quick link. http://www.bissell.com/parts/?id=9143&sc=product&productid=2813&cid=ccsocial Here's a quick link to locating a BISSELL Authorized Service Center if you need more assistance.
SOURCE: Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
The Tank-in-Tank system is designed with a bladder inside for
clean water. As you clean, the bladder will empty. Dirty water
collects in the tank outside the bladder.
