Could be a bad tcon or main board, below is the link for the manual if that helps
Philips 42 50 63PF9631D 37 Manual
SOURCE: Right side panel of my Philips TV is flickering
You need to replace a capacitor in the 'Horizontal' IC sectiom. If you are not a TV tech with excellent soldering skills and the correct testing equipment, I suggest you have a repair shop do it for you.
SOURCE: phillips lcd 47'' turn
Sounds like an issue with the power board or the wire harnesses from the power board to lcd control boards
