Sharp R-308J Microwave Oven Logo
Posted on Jan 06, 2009
Unlocking child lock on the sharp microwave model R316FSC
Will that cancel child lock advice given, (touch timer/clockpad, the number one, and touch stop/clear pad) work on all Sharp models of microwaves?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3259
Points
7
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3814
Points
10
Pick up your owners manual and review operation instructions.
2answers
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
Also, to find manuals........
1helpful
Unlockmy lg microwave oven
As with most situations, it depends on the model number, but try this:
To set child lock:
1. Touch STOP/CLEAR pad.
2. Touch and hold 0 pad more than 4 seconds. LOCKED will appear in the display window and oven will beep twice.
To cancel child lock:
1. Touch and hold 0 pad for more than 4 seconds. LOCKED will disappear from the display and the oven will beep twice.
2answers
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Goldstar microwave GMV 1540TW locked
    From the handy owner's manual here:
    To set child lock:
    1. Press STOP/CLEAR.
    2. Touch and hold START more than 4 seconds.
    "LOCKED" will appear in the display window with two beeps.
    1. Touch and hold START more than 4 seconds.
    "LOCKED" will disappear in the display window with two beeps.
    We're
    happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
    1helpful
    Sharp Microwave on "Lock" and
    The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
    3helpful
    I held CANCEL key too long and now the microwave is Locked. How do I unlock it?
    Press and hold the Clear/Off button for about 3 seconds again. This toggles the Child Lock.
    I hope this helps.
    (I used the model given above to check if the toggle command was the same or different from the lock command. If your microwave is a different model, try pressing the CANCEL button for about 3 seconds.)
    12helpful
    2answers
    How do I unlock the child lock on my Panasonic Genius Microwave?
    March 2009 press the function key,select option #5, select option#2. This should take it out of child lock. If this doesn't work enclose your model number and I will try to look up the manual
    Or, press "Cancel" three times to clear the (child) lock.
    You set the lock by pressing "Start" three times.
    I need to know how to unlock it
    The Child Lock is on.
    Your owner's manual covers it. If for some reason you don't have yours, you can download it free here.
    CHILD LOCK
    You may lock the control panel to prevent the microwave from being accidentally started or used by children.
    Example: To set the child lock.
    1. Touch STOP/CLEAR.
    2. Touch and hold START more than 4 seconds. LOCKED will appear in the display window with two beeps.
    Example: To cancel the child lock.
    1. Touch and hold START more than 4 seconds. LOCKED will disappear and you hear two beeps. At this time the oven is ready.
    1helpful
    Unlock a microwave
    hello jeansween ,
    can you double check that number please , R-4446 ?
    http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=r&s_func_disp_id=19&x=24&y=6
    heres a list of sharp microwave owner manuals .
    to cancel child lock you touch timer/clock pad, the number 1 and stop/clear pad
    hope thats understandable .
    Top Sharp Microwave Ovens Experts
    ZJ Limited
    ZJ Limited
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
