Straight Talk LG Optimus Zip Cell Phone Logo
Nikki Adams Posted on Dec 04, 2017
Mount SD card?
When I try to take a picture, it won't let me and says mount SD card. I go to the setting menu, select Mount SD card and then it tells me my SD card is blank. So I choose format SD card and it just loads for an hour and cuts off. Then this happens all over again. I've had this phone about 6 months. Help!
Mobicel Tango does not show mount sd card
Well for anything other than moving apps themselves, you can just set the specific app to save files to the SD card. Now if you are wanting to move apps to the SD card and have them run from there, you would need to do the following...
How to turn external SD card into internal storage on "Marshmallow".
NOTE: Please be sure you start with a blank SD card. It needs to be blank because when the card is converted to "Internal" storage, it will be formatted (wiped) and encoded (making the cards data only readable by that device).
1. Go to device "Settings", then select "Storage".
2. Select your "SD Card", then tap the "three-dot menu" (top-right), now select "Settings" from in there.
3. Now select "Format as internal", and then "Erase & Format".
4. Your SD Card will now be formatted as internal storage.
5. Reboot your phone.
NOTE: If you don't reboot the phone, many things may not work correctly, so make sure you do.
Nov 20, 2018 • Cell Phones
I have an Android ZTE N817 phone, and I want to know how to make my Sandisk Ultra Plus microSDXC memory card (64GB) my default storage. How do I do that?
in my zte phone the phone settings menu has a category labeled storage where you can mount, unmount sd card, get information on phone memory storage and sd card card storage volume used and volume available. It also has a button to select your default storage pathway, phone or sd card. Hope this helps you.
2answers
How do I mount my sd card
You will insert the SD card into the SD card slot on your device then you will power on the device and tap settings from the main menu click free format and then pick mount SD card when reformatting has completed.
In my wildfire s set sd & phone storage the mount sd card option is not working.in this menu total space is unavailable and available space is unavailable while the sd card is workin properly in other...
Delete all messages and call logs.......if still problem persists then probably there are some malware occupying your memory which creap in if u use internet on ur phone......solution is - factory restore ur phone after backing up only important data.....if this does not work then hard reset ur phone.....press vol. up, camera and power button together for a few seconds.......download/boot mode will appear......press menu or vol. down button and scroll down to CFT calliberation ...select using menu button......phone will restart....this should solve ur peoblem..
Sim card not ready
Try going to storage in the settings menu. See if it says mount or unmount SD card. If not just take out sd card n turn off phone. Turn on. Look in menu, see if phone recognizes there is no sd card. If so, good. Turn phone off. Remove battery 5 seconds. Insert battery and sd card. Turn on phone. Allow total boot process before manupulating phone. Go to contacts. If it doesn't read the sd card automatically then press add contact. See if it has add from sd card
DMC-zs10 records on internal memory - not on SD card
Hello bro..
Do you check your SD card? It is work ?
My solution:
1. Off Lumix camera.Until LCD was off. Press center of card to remove it.
2. Use card reader to connect your SD card to pc/netbook/laptop..
3. Check full capacity for SD card, it is empty(zero) or have it their mount.
4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal.
5. If still empty, that mean, your SD card was corrupted.
6. If not empty, backup all data in SD card.
7. Format the SD card using FAT32.
8. Checking Disk.
9.Insert back to camera, and format SD card using camera menu.
10. Take picture. and see if save on SD card or not. comment back here. if succes or not.
11. Don't use any battery except original from panasonic. It will affected to product.
12. Don't remove battery or card before lcd was off light.
Jul 24, 2011 • Cameras
1helpful
Change my SD card to a bigger space, and my phone it says,SD card blank.
You have to mount your sd micro. Click your menu key on the bottom left of your phone. Select settings, then scroll down and select "SD card & storage". There should be an option to mount the SD card. Select that and the phone will install what it needs to have on the card. You should now be able to use your card. I hope this helps.
1helpful
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 1helpful
    I can not get my pictures on my sd card
    Can you describe in more detail what you are trying to do, step by step, and how the process is failing?
    I have uploaded and downloaded pictures from my micro-SD card, both while it is in the phone, using a USB cable and setting the phone to "Menu | Settings & Tools | Tools | USB Mass Storage". Then the phone and the micro-SD card appear on my (Windows) computer as a removable drive, and I can just copy files in either direction.
    I am also able to remove the micro-SD card, and plug it into an SD-card slot on my computer (with a micro-to-SD card adapter), and it mounts as a removable drive that way, too.
    Note: if you have the micro-SD card in the phone, and you want the pictures you take to be stored on there so you can download them in one of the ways I've described above, then be sure to go into "Menu | Settings & Tools | 9. Memory | 1. Save Options | 1. Pictures" and set this option to "Card Memory", or else your pictures will get saved in the camera internal memory, and not on the card. This may be your problem if you are not seeing the pictures you expect on your memory card when you look for them. If you take Videos and/or Sounds, you might want to set those "Save Option" to the Card Memory, too.
    Top Straight Talk Cell Phones Experts
    ADMIN Andrew
    ADMIN Andrew
    john h
     Mikey
    Mikey
    Are you a Straight Talk Cell Phone Expert? Answer questions, earn points and help others
