I pulled cover and examined unit for broken springs or loose parts. - None found. I run just water thru cycle, no clothing, machine was still spinninig uneven but not as bad. Need help.
If you find no problems with the suspension rods and springs, you can remove that spin basket and check for an item that could be stuck between the spin basket and the plastic outer tub. Also, check the "balance ring" on the top of the basket. The should be fluid in it. You can check this my shaking the basket and you should hear water.
SOURCE: Washer will not spin
Josh, sounds more like the drive block or spin tube that is at fault. I will attach photos of each...Catriver..post back.
SOURCE: Tub and Basket
Fairway, sounds like you have a worn drive block. You are going to have to remove the agitator and inspect the drive block. If it is the drive block you will get some good hammering when the spin cycle stops. I will attach some photos of a worn out drive block. If you want to attempt to handle this yourself, we can walk you through it. Catriver..post back.
SOURCE: machine does not spin, clothes are soaked
fill washer and make sure it agitates. If it does not agitate but can here motor running you have a bad motor coupling. If it agitates but wont spin make sure lid switch is good, if good you have a bad gearcase.
SOURCE: Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
SOURCE: spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
