Big rubber seal around inside of door - gunk building up under and between seal and rotating drum? Is is safe to remove the seal and try to clear it out? Or should we call a technician? Just can't seem to get rid of the smell. Only liquid washing detergent and fabric softener used in the machine.
Ok, nothing to worry about. You have bacteria growing in your machine. Clean out the slime from the door seal using a soft cloth and soapy water. DON'T use any harsh chemicals such as bleach !
Remove your detergent drawer (if possible) and clean it thoroughly - a dishwasher will do this very well. Disconnect your machine from the power supply and clean thoroughly inside the space where the dispenser drawer was, using a toothbrush or larger nylon brush and a soft, soapy cloth.
Using liquid detergents all the time can cause a build up of residue over time, which gives the bacteria and mould somewhere to grow. So try a hot wash cycle (without a load) using a powder detergent intended for whites. Washing powders contain brighteners and chemicals which are hostile to mould and bacteria.
Finally, leave your dispenser drawer and loading door open every night to allow fresh air to circulate through the entire machine. This will reduce the number of cleaning occasions needed.
SOURCE: Fabric softener not draining during rinse cycle
What type of water hoses are hooked up to it? If you have the flood safe hoses with the check valve in them then there isn't enough water pressure to distribute the softener.
SOURCE: mildew smell in front loader
Yup! I have the same issue with a WE206BNW (Canadian model). Did the same thing - dried the water off the door and leave the door open when not using it. Sort of helped, but then I ran an empty light load with bleach through it - no clothes, just water. Helped a lot.
Henkfish
SOURCE: I can not seem to get rid of the mold smell from
I have a front loader and hated the machine for the very same reasons. A one shot fix does not exist but rather requires ongoing treatment (they don't tell you that when you buy the washer though).
Star by getting rid of the existing smell. There are products designed specifically for this problem. One such is "Affresh" but there are others. Most are available at stores that sell the machines and like everything else, on the internet too. Use as directed and once the smell is gone, maintain by using the steps below.
Firstly - discard all non-HE detergents. I know the "regular" detergents are cheaper than the HE counterparts, but these machines are designed for the low-suds types; the regular types leave a soapy residue because the machine doesn't use nearly as much water as your old top loader. So give them to your friends with top loaders instead of using them in your front loader.
Next, run a small load, with bleach and hot water only - no clothes as the last load for the day.
Thirdly, leave the door(s) open on the days not used. This includes any top door for detergents / softeners along with the main front door of the machine between washes. It need not be left wide open - but open enough to allow air in to help dry the interior.
Fourth, wipe down the interior after the last load of the day. Pay particular attention to the rubber seal between the drum and the door jamb of the machine.
Fifth, stop using fabric softener in the washer. Use a fabric softener dryer sheet instead. Limiting the products added to the washer to just bleach & HE detergents is best.
Sixth, use the washer cleaning product (Affresh etc.) as needed as a preventative step or to head off problems if / when they just begin to become noticeable.
If you follow all of these steps - the offending odors can be eliminated and prevented.
I hope this was very helpful and good luck!
SOURCE: The washer leaves water remaining in drum after
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
SOURCE: The smell that comes from this machine is
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hope your filter is clean. Don’t wait for the machine to jam to
look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such
things can be stuck around the inside tub of your washer. Try this product, it
works great on all front loaders. Use very hot water with the Affresh pellet
with no clothes and run the machine through a cycle. Also helps with any
stagnant water smells. Put the Affresh
pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help,
can't you. Thanks.
