I have Dell E193FPp 19" TFT LCD Flat Panel Monitor. I also have a Toshiba Laptop Satellite Model: E105-S1802. The Toshiba laptop does not have a 15 pin NGV or DVI port connector. It has two USB and one HDMI ports also it has a telephone or hard wired internet port and a SATA port. The Dell monitor has VGA 15 pin terminal. I am trying to connect a dell monitor as a second external display to my toshiba. So I bought a VGA to HDMI connetor cable on E-Bay and plugged the VGA end of the cable into the Dell monitor and plugged the HDMI end into my Toshiba laptop. I turned the power on both but the Toshiba Laptor did not recognize or eknowledge the dell monitor at all. The dell Monitor showed a screen that had multi-color square bar display across its own screen that was panning the screen. Does anyone know why this conection did not work? Is ther anyway I can make it work?
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
SOURCE: cannot read the model number (chinese)
Since the cable you're describing is a VGA cable with the 3-row, 15-pin configuration, it will be the 1:D-sub selection. The DVI choice is for HD TV or a display card with HD capability. The S-Video is more commonly used for higher clarity video signals--less than HD of course, but approximately 15% to 20% sharper than a co-axial cable signal. (Reason: co-axial cable has all the color sigs squashed together while s-video splits them out into separate feeds.)
SOURCE: Dell E151FPp 15" TFT LCD
It does not have DVI port, only VGA. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://support.dell.com/support/edocs/monitors/e151fpp/En/attach/attach.htm
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: Dell E172FPt 17" TFT LCD Flat Panel Monitor powers
It will need parts or board repalcement. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Board is only $30, http://www.lcdrepair.us/e172fpt-inverter-power.html
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r7406380-tv_training_manuals
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
