Checked motor, gearbox and speed control, everything seems to be working fine. If I turn the speed control all the way up the speed isn't fast enough to weld.
SOURCE: wire feed motor wont run
Do the wire drive wheels turn?
if not then trouble shoot wire feed system for defect.
SOURCE: no arc for craftsman professional wire feed welder
either your not grounded on the vehicle very good or you lost the ground either in your gun or on your clamp
SOURCE: The wire feed on my welder will not work.
Dale,
Probably the trigger/ open the lead and try to short the connections for the trigger by bypassing the trigger acuator. This is the mechanism that activates the wire feed motor and applies the welding voltage to the wire. If this works, get a new torch handle.
SOURCE: I have a Lincoln wire feed SP-200 welder and my
Try replacing the circuit breaker. They can/do get weak and tend to trip before they actually reach the rated limit.
