Had a leak around the base of the fixture. American standard sent me a new cartridge, o- ring, and main body piece that appears to have a gasket on the bottom. They did not send instructions, thanks.
Unscrew a alen screw on the underside of the handle.
unscrew the cap that is holding the main body of the fixture.
pull up the fixture.
install in reverse order.
Thanks for your help. On this faucet I can not locate the screw that removes the handle.
There is a pea sized medallion half- red half blue. I pulled that out but could not see the screw. I assumed that this is where it would be hidden. Also , if the screw is there, is it to be removed in the off position? Thanks
Will try today, thanks
FAUCET LEAKS FROM BAjSE OF UNIT
