Try these procedures.
SOURCE: my Sanyo VPC S670 - digital camera lence is stuck
My camera had the same problem it would turn off after i tried to take a picture and it would say lens error 112 all i did was put duracell batteries in it as soon as i did it worked it seems wierd but try it its cheaper than getting a new camera
SOURCE: my sanyo vpc-e760 digital camera is showing lens error:22 what do i do
well i have a SANYO camera and every time i cut it on it cuts on a little bit and i see it and it sais lens error: 308 what does that mean?
SOURCE: Lens will not retract on Sanyo VPC-T850, 8.1 megapixel, digital
Did you drop your camera? If yes you either damaged the lense mechanical parts. If some dust or small particle are on the side of the lense, it may prevent the lense from opening up. If the lense opens up and down a little bite try to pull it out by have very softely. If it opened fully, clean up the outside of the lense and turn your camera a few times. If it does not have a mechanical problem, it should be back to normal. If above did not help, the lense has to be taken out and inspect for broken or damaged parts and clean it and put it back on the camera.
Good Luck!!!!
SOURCE: Lens Error: 0x12110000 when previewing pictures in camera.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: VPC-S1414P 14MP Sanyo Digital Camera
Hi.
The lens are probably stuck out because of a defective ring in the lens assembly. There are tricks to help lens back in (e.g. see Lens not retracting or Lens Error). Do not try the trick proposed in the articles.
Trying to fix the problem by yourself you risk to invalidate the warranty. My advice is to call Sanyo or to go to a Sanyo authorized reseller. DO NOT attempt repairing the problem by yourself before contacting support.
The fact that camera has not been exposed to any impact, sand or liquid damage should warrant you full repair cover. Repair will be carried by the manufacturer or by a local authorized technician.
I hope that you will understand that experts are not responsible for your situation. We do our best to help the users. Sanyo products deliver good performance and quality. I am sorry about the unlucky occurrence.
If you have any query about your payment to Fixya, please write to [email protected] , post a cc message to [email protected] . All requests will be dealt with in two working days.
The feedback given to the experts does not affect in any way your rights and your customer status.
Best regards.
Ginko
Expert Moderator @ Fixya.
