How long have you had the phone? If you don't have alot of data or pics.........do a factory reset.........then everything should work fine......you just have to start all over////try finding a manual online.......I don't trust phone techs that much....made problems worse!
SOURCE: cant send photos
Text messages are for text only. Pictures must be sent using Multimedia Message (MMS).
SOURCE: HTC
Try this link:
http://forums.wireless.att.com/cng/board/message?board.id=cingular&thread.id=84238&page=1
this should be happening because of SMS memory full ... after it the messeges can not be sent .. or can be the connection problem..
SOURCE: wont send or receive sms
On your storage card you will have a folder named inbox and another folder named inbox."some random numbers".You must delete the folder named inbox."some random nubmers". For example inbox.m63jh47523
SOURCE: Cant send message...
Tap Start >> Settings >> Phone, go to Services tab, select Voicemail and Text Messages and tap Get Settings. You may change the service center number from here. In case you do not know the correct number, call up your SIM provider and get the number from them.
