E-Machines T1090 PC Desktop Logo
A
Anonymous Posted on Nov 10, 2012
EMachines. T1090 Intel Celeron Processor format
2 Related Answers
Anonymous
  • 57 Answers
  • Posted on Nov 12, 2009
SOURCE: EMACHINES T1740 Intel Celeron 1.7 GHz
The following shows specs for your system to get http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T Series&model=T1740
I was able to get as far as the Intel 845GL chipset and now i need the actual type of motherboard. Take off the cover and it should be something like S2098AGN. You can do a google search for your "Motherboard model + manual + download" and you should be OK. Hope this helps, Best Regards, -md
Testimonial: "tHANK YOU "
Anonymous
  • 128 Answers
  • Posted on Sep 10, 2010
SOURCE: I need to know how
Hi!
The maximum capacity your machine can accomodate is only up to 512MB. The board has 2 slots for 2 memory sticks that can accomodate 2 256MB memory module at max.
Should you have any other question please leave a comment.
Cheers~
Installing new cpu on a emachine
According to the specs I have Serena, the eMachines eTower 633i Desktop PC, uses a TriGem Cognac motherboard.
[TriGem is the manufacturer, Cognac is the model.
Note it is Not the TriGem Cognac+ ]
http://www.motherboards.org/mobot/motherboards_d/Trigem/Cognac/
Specifications. (You can click on the photo to enlarge)
PDF motherboard manual,
http://www.elhvb.com/mboards/TriGem/manuals/index.html
Click on - Cognac - in the left side of the list.
Going back to the Motherboards.org page;
(Nothing like upside down photo information, and the motherboard is turned 90 degrees to the Right, to how it actually sits in your computer case )
The processor socket is a Socket 370,
http://en.wikipedia.org/wiki/Socket_370
Used for Intel Pentium III processors, and intel 'Celey' processors.
(Excuse me......Celeron.
An Intel Pentium III processor has TWICE the L2 cache, that a comparable Intel Celeron has.
The cache for a Processor is a small memory area for the Processor.
It is the First memory the Processor accesses.
The Ram Memory is second, and the Harddrive is third.
More cache for a Processor makes it more faster )
The motherboard chipset is an Intel 810.
The Northbridge chip of the motherboard chipset, is an Intel 82810.
The Southbridge chip is an Intel 82801AA, or an Intel 82801AB.
(Intel ICH, or Intel ICH0 )
Looking at the chart, and reading across, you can see what the Intel 810 motherboard chipset supports;
1) Processors: Intel Celeron, or Intel Pentium II, or Intel Pentium III.
2) Processor Front Side Bus: (FSB) 66MegaHertz, or 100MHz.
3) SDR Sdram ram memory at 100Megahertz.
[Single Data Rate Sdram is often just referred to as Sdram.
Erroneous.
Double Data Rate Sdram is also Sdram (DDR Sdram)
Synchronous Dynamic Random Access Memory
So is DDR2 Sdram, and DDR3 Sdram ]
Also referred to as PC100.
So when looking for a CPU you look for;
1) Fits in a Socket 370 processor socket.
Yep. The best is going to be an Intel Pentium III.
2) Has a FSB of 100MHz.
Hmmm,............
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_III_microprocessors#.22Coppermine.22_.28180_nm.29
Scroll down.
Pentium III 1100.
Maximum frequency rate ('Speed') is 1.1GHz (1100MHz)
Front Side Bus = 100MHz
Uses a Socket 370 processor socket.
Part Number = RB80526PY005256
sSpec Number = SL5QW
http://www.cpu-world.com/CPUs/Pentium-III/TYPE-Pentium%20III%20%28Coppermine%29.html
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201100%20-%20RB80526PY005256%20%28BX80526F1100256%29.html
In the top header -
Specifications / Pictures (1) / CPU ID (1) / Comments (1),
click on Pictures (1)
You can click on the photo to enlarge.
256MegaByte of L2 cache. (256MB)
A comparable Celeron would have 128MB of L2 cache.
http://www.recycledgoods.com/products/Intel-SL5QW-PIII-Processor-1100-256-100-1.75V.html
http://www.impactcomputers.com/sl5qw.html
[ Don't forget to follow Anti-Static Precautions.
Clean the bottom of the Heatsink THOROUGHLY, and the top of the Processor if it needs it. (I always do anyway)
PROPERLY apply fresh, new Thermal Paste.
For additional questions please post in a Comment.
Regards,
joecoolvette
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
3answers
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
I need emachine etower 600is intel processor
The eMachines eTower 600is uses an Intel Celeron III processor that operates at a maximum frequency rate of 600MegaHertz. (600MHz)
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=eTower%20Series&model=eTower_600is
The Intel Celeron 600 uses a Socket 370 processor socket.
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#.22Coppermine-128.22_.28180_nm.29
There is a locking arm on the side of the Socket 370 processor socket, that is unlocked by easing the arm over to one side to clear a lock tab, then the arm is lifted up to remove the processor.
Example of a Socket 370 processor socket,
The eMachines eTower 600is uses an Intel 810 chipset, for the motherboard chipset.
[Chip and Chipset are slang terms used for Integrated Circuit, or IC]
The Intel 810 chipset, supports processors with a 66MegaHertz Front Side Bus. (66MHz FSB), or 100MHz FSB.
In an additional link, I will give a recommendation of where to buy an Intel Celeron 600, that uses a 66MHz FSB.
I'm not advertising for this place, it's just a place I have used, and have had good results.
Also information on the Intel 810 chipset.
You could also use an Intel Celeron 700MHz processor, but better still you could use an Intel Pentium III 933MHz processor.
Pentium's typically have Two times, the L2 cache that a comparable Celeron has.The more L2 cache a processor has, the faster it's going to process information.
I also know it will work because out in my shop I have an eMachines T1090, that has an Intel 810 chipset, uses a Socket 370 processor socket, and has an Intel Pentium III 933MHz processor in it.
(Made in 2001, and still works good to this day)
The Intel Pentium III 933MHz processor uses a 100MHz FSB.
The Intel 810 chipset supports processors that have either a 66MHz FSB, or a 100MHz FSB.
If you are not familiar with computer hardware technology, then I have just thrown a whole lot of information at you that is unfamiliar.
Should you like me to break down the information, I would be glad to. Just state so in a Comment.
1helpful
I have a acer aspire m1610 intel celeron 430, wat processer can i replace it with?
Intel® Core™2 Duo processor (with up to 800 MHz FSB)
Intel® Pentium® Dual-Core processor
Intel® Pentium® D processor
Intel® Pentium® 4 processor
Intel® Celeron® D processor
Intel® Celeron® processor
RICHARDM69
6helpful
4answers
Connection between emachines case and motherboard
Most likely the wires are for power, reset, and hard disk light. Touch one pair together momentarily, if your compter comes on then connect those wires to the power button. After the computer is on, connect the other two pair to the hard disk light one pair at a time until you see the light activate when the hard disk is running. Then connect the remaining pair to your reset button.
UpGrade
download cpuz it will tell your specs
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
