On your oven, look in your manual and you can calibrate the oven +/- 35 degrees.If it is out of the range of calibration then replace your oven sensor or themostat which ever one you have.On your fridge I would recheck your drain hose from both ends and puor boiling hot water down drain.The only 2 reasons why you would have water on bottom of fridge is 1 a water leak or cloged drain.good luck
