When trying to download football manager 2012 steam was loaded but on steam update it ran very slowly up to 99percent then crashed and quoted that there was an open trojan threat,which I chose to repair. I then tried to open steam and it came up that there was a fatal error
SOURCE: laptop crashed
Question: So that we know what the options are before we go down this path: -is there data on this laptop you have to have? -Do you have the original installation CD from Compaq?
SOURCE: Windows fails to start and startup repair does not work.
Your startup repair option in Windows Install indicates a hardware conflict. Go to your System Setup in startup mode, by pressing Del, F2 or F10 whichever the hint is on screen during bootup. Once inside system setup, turn off almost everything, disable Speed Stepping in EPower, set monitor off to disable, Standby and Hibernation off as well. Turn off the modem and Network adapter if yo can. Just about everything that affects a device on the laptop. This would also include the Touch Pad if you're using a mouse.
And, in the long run, you may need to do a full Windows Install if the repair option continues to fail. Many of these failures are due to the Virtual Memory file size for Drive C being too low. If you can get into Safe Mode change this setting, right click My Computer, select Properties, go to Advanced, advance and change Virtual Memory on C to a fixed size about 1024Meg for min and max.
Also, should you be low on free space for drive C this could cause the same problem. You would have to choose a Full Install as an Option unfortunately.
In the absence of anything along these lines working, you should be able to choose Restore Acer option (or words to this affect), you would want to tap on F8 while booting, sometimes its F10, but this gives you a 'boot from what source' option, CDROM, Hard Drive or Restore Partition. Choose the Restore Partition and start over from scratch again.
Sorry, but this often happens and you and I have to live with this.
If you need any clarifications on what I've just stated, use the Comment Box Text Entry box below to send me a message. I'll get an email alert and will get back to you as soon as I can.
Regards,
Worldvet
SOURCE: repeated blue screen saying fatal system error - c000021a
go to http://www.grc.com and purchase spinrite. It may recover the disk for you
SOURCE: E-475m just crashed. Won't load windows. Will let
Try this fix.....
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
SOURCE: my daughters tecra m1 refuses to format and
Either the HDD controller is bad or the HDDs you used have bad sectors.HDD regenerator software alot of times will correct the bad sectors and then the OS will install correctly and function smoothly.
