I've installed TP-310U to Samsung SCX4623F in my home network using Linksys WiFi DSL router and it worked. But after installing MyBook Live network drive printserver doesn't work and driver displays some errors. Afer disconnetcing drive everything works fine. How can I install both network drive and printserver?
SOURCE: Printers are not recognized as online by printserver
Have you check which port your PC trying to register your printer to?
SOURCE: Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
SOURCE: 3 com 3crwps10075
Don't know if you have fixed the problem, but one solution is to turn off the Windows Firewall.
SOURCE: Where did my printserver go !!! ???
"... your print server is configured with DHCP and not a static IP address (If it is has a static IP address, make sure it is configured for the correct subnet) ..." How can you verify that if you can't get to the printer server URL?
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
