The heat/dry lamp and clean type lamp (standard, fast rinse, heavy etc) come on but nothing else does(cancel, start, cycle). Tried disconnecting the keyboard. With power on and the door shut, i disconnect and reconnected the thermistor twice within 2 seconds. Nothing happened, total silence. Also tried doing a continuity check on the keypad by measuring accross a combination of pins while pressing the corresponding keypad button. The reading went from infinity to several MegOhms. Tried reversing polarity with no success. Any ideas
SOURCE: KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
SOURCE: Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
SOURCE: Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
SOURCE: KUDS02SRSRSS1 dishwasher.......remodeling kitchen,
there is no reset/or code in the buttons . you might have the child lock on look for the lock on the panel and push and hold for 3 sec . should unlock panel. . Hole this will help feed back pls mm
Hi - If the unit is not drying nor cleaning properly, there are two main things to check first. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater. Are you using rinse aid? Use a rinse agent to increase drying performance and using Sanitize or Air Dry Off mode also helps improve drying. If any proves to be ineffective, contact a professional to move forward accurately. Unit may have a faulty heating element a communication problem with the board not responding.
