The 'incompatible cartridge' error message is not a common error message associated with the Photosmart C5180 printer model - in most cases when the HP02 cartridge is not recognized, or has poor connectivity, you will normally receive an "Unrecognized Cartridge" or "Cartridge Problem" error message with a big RED X; in most cases (like 99.3%) the smart chip needs to be replaced with a new one - please note the chip life has 25 month expiration window from the time the cartridge is initially installed into the printer. Costco and Fry's Electronic's provide this top-notch refilling/programming service today.
I suggest
you also verify the permanent built-in PRINTHEAD performance inside this
legacy printer model (either one of the procedures below applies to all
printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please
visit our HP02 system support page which includes videos of everything
mentioned below:
http://inkjet411.com/?page_id=1372
A. HP02
ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap
43 PRINTHEAD Health Diagnostics:
Video Procedure:
http://inkjet411.com/?page_id=2391
1.
Press * and # keys simultaneously.
2.
"Enter
Special Key Combo" will be displayed.
3.
Press 123 to display the 'Support/Service' menu.
4.
At 'Support/Service' menu, click the Right Arrow
3 times until Special Reports menu is displayed.
5.
Select Ok, then click Right Arrow 2 times until the
'print-mech button tap' menu is displayed.
6.
Select Ok ('code = 0' will be displayed); click
and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you
need to decrease numerical count.
7.
Select Ok. The test page prints.
8.
Check the 4th line at the top of the printed
report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen
Status: Pen OK".........if any other message
is displayed then the PRINTHEAD may have failed and may need to be replaced (if
part is still available). It is suggested to perform the 'Printer Reset'
procedure below to first rule out printer firmware related problem.
B. HP02
ink-series printer models that DO NOT HAVE a KEYPAD:
Internal Test Print:
1. Press the Menu button, press
the Right Arrow button to select 'Tools', and then press 'OK'.
2. Press the Right Arrow button
several times to select 'Print Test Page', and then press 'OK'. The test page
prints.
Tap 43 PRINTHEAD Health Diagnostics -
See Video Procedure:
http://inkjet411.com/?page_id=2377
1. Turn
ON the printer.
2. Press
and Hold the "Print Photos" & "Red Eye Removal" buttons.
3. Release
both buttons.
4. You
will see a new screen that says, "Enter Special Key Combo"... The Key combo is:
press and release in sequence the "Red Eye Removal", "Print Photos", and then
"Red Eye Removal"
5. Scroll
through the menu by pressing the right arrow button until the display says
'Special Reports'.
6. Select
Ok, then press the arrow button until the 'print-mech button tap' menu is
displayed.
7. Select
Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43'
is displayed.
8. Select
9. Check
the 4th line at the top of the printed report; an electrically good/stable
PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is
displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is
not replaceable). It is suggested to perform the 'Printer Reset' procedure
For additional and advanced HP printer diagnostics,
please visit:
http://inkjet411.com/?page_id=1813
To help solve other HP02 ink-series printer/printing
related issues please visit
http://www.inkjet411.com
