Codes to check are 078,026,041,074,033. If you wish to get more details, visit this
site. It has setup codes and setup
proceedings to many popular brand remote controls. Pull up older posts there. Check the site with patience, as it has over 2075 posts now. All are related to electronic equipment
repair help.
If you wish to get setup codes, three
digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to
some popular model remote controls are given. Select the 'Timeslide'
option from the drop-down list by the 'Sidebar' at the display
window. It will make search. easy.
window. It will make search easy.
General setup codes to Emerson brand TVs are 0039,0018,0073,0081. Check these codes first. If you wish to get more setup codes, three digits, four
Pull up older posts. Setup code
list and setup instructions to some popular model remote controls are given. Check the site. It will surely help you to find out a replacement remote for your TV. Refer the code lists there.
0834,0183,0291,0829,0154. Check these codes. If you wish to get more setup codes, three
digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to
If you know the 5 digit code to unlock your door, press the 5 digit code followed by the number 6. This will pop the trunk. To change the unlock code, press the 5 digit code, followed by the new code you wish to use. Keep in mind, the new code will be lost if the car should lose power and revert back to it's original code.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
