Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean filter inide hose.
Refit and test.
Please rate my solution.
Thankyou.
This motor does not have brushes fitted, the error code F01 indicates that the motor triac has shorted, this is part of the electronics that control the motor, it could possibly require a new main pcb, and/or new motor. If it is under 5 years old, then you are better off contacting Hotpoint, and getting it done under the 5 year part guarantee.
Plz rate my solution.
Thanks.
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
