Im thinking maybe the buttonhole foot is damaged
You should a buttonhole button that must be pushed on the machine
either before you pull the buttonhole lever down or after to let the
sewing machine know what function to use, my sewing machine
won't let me make a buttonhole unless I push the buttonhole button
or yes, like you said the buttonhole foot could be damaged.
SOURCE: Singer 7462 buttonholer
generally most sewing problems are due to sticking parts because of non usage as =you have stated or because the tension has been not set right. what I suggest is that you take the time to do some cleaning of the machine like what bis pointed out in your manual use a light weight mineral oil to wipe the moving parts with, but not too much. also adjust the tension of the foot so there is pressure on the material as to move it while sewing. after all the cleaning and adjusting rethread the bobbin and make sure it is seated properly also rethread the need and make sure the thread moves freely from the spool. this should do the trick. please rate this
SOURCE: buttonhole lever
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
SOURCE: What foot do I use for strraight stitching I have
Ideally you want a foot that looks like this with a very small hole where the needle goes down, to maximise the pressure onto the fabric. Just don't move the stitch setting to anything that swings the needle or you'll smash the needle onto the foot and risk damaging the machine.
But unless you are having issues with the fabric being pulled down into the feed dogs, the regular clear sewing foot should be fine for most work and is certainly easier to see what you are sewing.
A lot of quilters go for a 1/4" foot too which gives you consistent 1/4" seam widths when piecing quilts. There is a excellent website on sewing machine feet and their different purposes, link is
http://sewmamasew.com/blog2/2009/06/feet-feet-feet/ and she has great images of 1/4" foot in use along with others such as Open Toed or Roller foot.
If you are shopping for different machine feet, you may like to look at www.sewingpartsonline.com, great website with lots of different brands. Your machine would be classified as a "low Shank" machine I think; often you can buy a generic brand foot which will work on different brand machines once you are sure of the shank type.
Most sewers find that there will be one foot they prefer to use for much of their work depending on their projects. My all time fav is the Elna Teflon foot, a black teflon coated foot which works great on many different fabrics; I've worn the black off the bottom of two of them!!
