LG DLE2532W Electric Dryer Logo
Jamey Johnson Posted on Nov 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced the thermostat on my dryer, and it worked for a few loads of laundry. Now it won't heat again. I tested it by bypassing the thermostat (hooking two wires together) and it will heat that way. Is there a reason why the thermostat would burn out again so quickly?
Richard Roth
Level 3:
Top Expert:
  • LG Master 9,472 Answers
  • Posted on Nov 09, 2012
Richard Roth
LG Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626558
Points
28464
Which thermostat is it? Do you have a part number? Look on the thermostat for the number.
Replaced coils & igniter but dryer won't heat. Tested all thermostats and they read good. Can't see if the igniter is glowing or not.
check psu to ignitor and the main burner valve sets and resets
you can do this manualy by removing the thermocouple and testing the burners does it try to strike??? and doesnt burn or does the burner try to come on then go out if it wont strike perhaps the door catch isnt right you dont give a make model etc details so its hard to even guess,,,?
Dec 20, 2014 • Dryers
Whirlpool dryer not running
If this a conventional dryer have you tried a temp switch located in the console panel
Samsung electric dryer keeps burning up thermal cut-off thermostat
I am not familiar with the model.
That the thermostat keeps failing, due presumably to overheated/burned contacts does indicate the element is drawing too much current. I can think of no other reason to explain your experience except possibly there is excessive arcing at the contacts as they open and close. The addition of a suppressor capacitor might help but the big question to be answered is why is there too much current or excessive arcing...
I can only suggest you thoroughly examine the heating element looking for breaks and accidental short circuits between the coils of the element or connecting wires.
Feb 28, 2017 • Dryers
1helpful
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 • Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
3helpful
Electric dryer won,t heat/replaced heating element last year,dryer worksbut won't hea
Hi galepezz...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Hi galepezz...
Check your Wiring
The dryer can take an entire day to dry a single load of laundry.
Hi ted wilby...
Check your Wiring
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
1helpful
2answers
Our Siplicity dryer (model: SCD5505W) is not heating (the air is cold) We don't have Instruction Manual.
Hi istvan314...
Check your Wiring
Jul 16, 2011 • Dryers
My whirlpool dryer runs but it won't heat up. It is only 6 years old. Dry maybe 8 loads a week in it.
Hi magicman1023...
Check your Wiring
Top LG Dryers Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Dryer Expert? Answer questions, earn points and help others
