When I first close the door it makes all the right noises but then stops and begins beeping intermittently. When I open the door they 2 lights are flashing. The manual says to clean the water tap and/or turn it off and then on again. I really do not know where this tap is to be found. Can you help. Btw all the filters are clean so that's not the problem. Any help appreciated.
SOURCE: Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
SOURCE: Ontegrated dishwasher door fitting
Just fitted on of these & found the door very easy to fit.
The instruction sheet is actually a template as well. Attach it to the back of the door & where indicated drill 2mmø holes to a depth of 14mm. Firstly then screw in the 2no. screws that go into the door slots, the actual screws are easy to spot as the screw thread finishes approx 5mm from the head.
Once that is done you need to offer the door to the front of the dishwasher & slot it into place. Once done you have to fix the door in place with the 6no. longer screws. To do this you must remove 4no of the screws which are holding the front of the dishwasher together, the other 2 screws go through empty positions at the bottom of the dishwasher door.
To help with this process I would recommend you use a soft jawed clamp to hold the door in place whilst you screw it in place.
There are also 2no. angle brackets that fit into 2 slots on the top of the dishwasher which are then used to hold the dishwasher in place under the work top.
Hope this helps.
p.s. one last thing, the thin strip of steel that comes with the kit fits onto the underside of the worktop in the position shown, I believe this is a steam deflector to protect the underside of the worktop
SOURCE: AEG Favorit 665i. Lower arm does not turn
im not sure about this if the upper arm is working ok,because the lower arm gets the pressure first then sends it to the upper arm,if the water pressure to the machine is ok then the lower arm is at fault take another look at the lower arm something is not right with the lower arm.adrian;;
SOURCE: favorit 44070 3 flashes on end of cycle light. No water loading. Does not start
you need a water valve if the overfill float is not malfunctioning
SOURCE: AEG FAVORIT 35085 Vi dishwasher Beeps 5 times and stops
If your AEG FAVORIT 35085 Vi dishwasher beeps five times and stops halfway through a wash cycle, there could be a few potential causes for this issue. One possibility is that there is a problem with the water supply, such as a clogged or partially blocked inlet valve. Another potential issue could be related to the drainage system, such as a clogged filter or a malfunctioning drain pump. It's also worth checking if the dishwasher's spray arms are spinning freely and not obstructed by any debris. If the problem persists, it is recommended to consult the dishwasher's manual or contact AEG's customer support for further assistance. They can provide specific troubleshooting steps and guidance based on your dishwasher's model and any error codes that may be displayed.
Testimonial: "Thank you for your prompt response. I will follow your advice and let you know how I get on. Thanks again Geoff"
