My 1991 oldsmobile cutlass ciera 3.3L has been giving me a problem, sometimes when I step on the gas it's sluggish & then it picks up and drives normally, but if I have to stop for a light or stop sign it struggles to accelerate and then it runs normal again. This keeps happening. Does anyone have a solution? Please help!!!!!!!!!!!!!
SOURCE: The windows in the 95 oldsmobile cutlass ciera won't work at all
maybe the wire is severed where the door (drver dr) pivots. thats what was wrong with mine. there is a rubber boot with crinkles in it that hold all the wires together. you can also try replacing the switch board that controls the wndws on the drvr dr. hope that helps.
SOURCE: 1988 oldsmobile cutlass ciera check engine light on then stalled.
I had a chevy celebrity that was throttle body also...went to leave a stop sign, light came on and car died and refused to run. We went to the junkyard and got a replacement throttle body for 20 dollars and installed it...it ran perfectly fine after that. Hoping your fix is as easy as ours was.
SOURCE: 1991 oldsmobile cutlass Location of starter
Follow the red wire from the battery towards the firewall. It will end at the starter.
SOURCE: 1991 Oldsmobile Cutlass Ciera idles high
Change your idle control sensor, but first make sure your throttle linkage isn't sticking.
SOURCE: my 88 Oldsmobile Cutlass Ciera is running rich and
The Oxygen sensor is very suspect. it is easy to damage on install, even with the correct tool.
Put the old one back in and test the car...
Could it be that i need a new fuel pump
