SOURCE: i have a set of Behringer B215 passive eurolive
Check the DC resistance of the speakers. I should not be over 10 ohms. If it is something, probably the speakers are blown.
That 600 Watts is peak and you should use an amp of say 300 Watts a side max to drive this for safety.
You may find a fuse inside, but not likely you would be so lucky... Also if the amplifier failed it could have sent DC current through the units and fried the voice coils of the woofers. The horns often have capacitive coupling and usually will survive.
You can fiond 15 inch replacement speakers on Ebay... HOWEVER get the dimensions as they often vary and may not fit.
