Olympus FE-190 Digital Camera Logo
Posted on Jan 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot shoot videos direct-to-pc using Fe-190
I lost my cd rom, i can't use my camera as an imaging device since it was not installed as an imaging device. i can only transfer pictures. but i cannot shoot videos direct-to-pc using Fe-190
Anonymous
Level 3:
President:
  • Master 919 Answers
  • Posted on Jan 08, 2009
Anonymous
Master
Level 3:
President:
Answers
919
Questions
0
Helped
348035
Points
2397
The camera can not do that kind of functionality - it does not have the capability to be set up in any type of control mode. There are some Olympus cameras that allow for this unfortunately this model is not one of them.
1helpful
Hi, i want to use my olympus fe-190 as a webcam what do i need. thx
Unfortunately you can't use the FE-190 as a webcam. It was designed as a camera, storing still images (and incidentally, videos) to a memory card. It was not designed to stream live video to another device.
I know this wasn't the answer you wanted to see, but there it is.
Aug 09, 2010 • Cameras
2answers
Lost cd driver so unable to update driver in device manager page.. where can found free download of that driver
cd driver ??? what OS u using ? what brand pc cd roms/dvd roms normaly install them self with windows drivers ?
I have lost my cd to put pictures onto my computer from my olympus fe-190
Use a card reader to download your pics to a folder you create on your desktop
1helpful
I lost driver cd ,i need drivers & software
There are no drivers needed for the Olympus FE-190. Once connected through its USB, the computer will treat it as a USB mass storage device similar to a removable /flash drive.
If for some reason the PC won't recognize the camera, it is probably a problem with the USB cord, the USB port or the memory of the camera.
Alternately, you can use a memory card reader and slip in the memory card of the camera to gain access to the content/pictures.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Fe-190 can't be detected as Imaging device
If you are using a Windows computer 2000/xp/Vista
you need no software Windows has all the facilities it needs.
If the Computer cannot detect the camera when it is plugged in to the computer USB socket and switched on and set to up load.
Then there would appear to be a fault with the camera or battery.
I suggest you remove the card from the camera and try to get it read by a friend or processing station to establish if in fact the card has images/data on it.
the fe-190 is only detected by the computer as a USB mass storage device and only allows you to download images from it. It can not be used as an imaging device when connected to the computer.
3helpful
4answers
Need a driver for FE-190
need a driver or cd to download my pic on my computer olympus FE 190
Help please
1. plug usb into PC
2. plug usb into camera
3. turn camera on
Windows should report that it is detecting a device. If it doesn't then it may be because the camera's hard drive IS the device it would supposed to be detecting, nes pas?
Lost Cd
Actually, if you're using XP you should not need the disc at all to shoot & download images. If you're looking for software so you can crop & that sort of thing, I recommend googles Picasa program, its free. To download images without the disc simply connect the camera like you have in the past and XP will find the device & walk you thru downloading images, usually. If not, click on "my computer" and you should find your camera/device listed there. Personally, I use a card reader and take my memory card out and download the images using the reader.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
