I trie to charged map of panama city and dont work
and show me this message alltime
"No detailed maps found that support routing the nuvi cannot be used without them"
is possible make a formart this like a harddisk for restar the software?
please help me because I need this hel
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
From the Garmin web site:
Question:
What should I do if my Garmin nuvi / zumo displays the message “No Detailed Maps That Support Autorouting.”?
Answer:
Please follow these steps to troubleshoot the error message:
Checking the unit:
I had the same problem. What you do is place your finger in the lower right corner where the green button would be and cut it on. When the prompt comes up, click yes. when the no detailed maps comes up again, hold down the green button again. You should then be able to upload the maps.
SOURCE: garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
SOURCE: Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Please dont forget to vote if you liked my answer
thanks
I have a nuvi 260w. The other day I was using it wasn't aquiring any satellite signal for a long time. I switched it off and when I put it back on I got the message "No detailed maps found that support routing.The nuvi cannot be used without them" Can anyone help me with this ??
I was trying to upload maps to my nuvi 200w using the IMG2gps software. Now when i turn it on I get the error "No detailed maps found that support routing.The nuvi cannot be used without them."
Tried to download free update and got the same message. I've done everything but call Garmin. What the hell! Why can't things be easy?
