I tried hooking it up to different headphones and speakers still no sound i think i need to replace the actual jack but i dont know
Your headphone jack can be replaced without problems. There are third party Zune repair services, that will fix it for cheap. Even better, I found an DYI Zune repair guide, soyoucan do it yourself too, not that difficult. Part is availableon Ebay. If you can't do it yourself, have a tech savy friend do itfor you.
@ tp984 If your Zune was submerged in juice (or any other liquid) it is likely liquid damage. Unfortunately you are probably out of luck. You can always try the old putting it in a bag of rice trick, but it is probably too late for that.
SOURCE: My Zune wont play music anymore
try to rest it if that is not working download the upgarding firmware utility
and give it a a firmawre upgrade.
http://support.microsoft.com/kb/926770/en-us
plz rate as good as u can so we can help others.
SOURCE: Can't upload music onto zune!
Mp3 format is OK - I would reformat the player inside of Windows Media Player and try again.
SOURCE: How can I sync music onto my zune 120GB without using zune softwa
you have to use it or you wont be able to download music.....most computers dont recognize zune software...only apple software
my zune was soaked in juice and while the unit plays, no sound. Any suggestions for this type of issue
i have the same problem but mine has not been in any liquid what do i do to fix it. it shows it playing songs but no sound. and sometimes after it sits there playing for awhile it will just start play sound but by then the battery is half dead.
I was just listening to music an hour ago. I turned it off and turned it back on and now its playing but no sounds... what do i do!
sAme problem, last time i used my zune it worked fine. Now, it plays music and videos but NO sound. any help?
i have the same problem it depends what kind zune you have because theres different ways of fixing it
