SOURCE: XO Vision XOD1736
i just buy this product for christmas it was working fine but after a few days the scren became white and lines on it.
SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
SOURCE: everytime i take turn the car on or off the radio resets to defau
If you are losing the memory (clock and presets) on the unit, you need to make sure that the yellow wire (normally) has 12 volts AL THE TIME and the red (acc) is switched on and off with the key. The battery wire (memory consant 2 volts) is the one that retains memory.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: xo vision dvd player
hi there
it shouldn't be to hard to install this but it does require cutting a hole in your interior part of roof........a install like this could take anywhere from 30 mins - 1hr for a installer to put it in. to do it yourself it could take 1-3hrs to complete (note for your first time doing this take your time and follow the install manual that will be provided)
SOURCE: I can't get my xo vision xo1915bt cd player to play my ipod
You cant get it to play your iPod with the USB connection. The only way to get it to play an iPod is if you hook up the AUX connection located in the back of the unit. get yourself a red/white to 3.5mm cable (3 ft should do) and run it through your dash into a location that will be convienent to put your iPod. The only other way to play an iPod is if it is one of the newer touch models that has Bluetooth. Then you can use the A2DP connection to play it wirelessly.
In short, the USB is only for charging your iPod, or playing music on flashdrives.
