Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi rear projection tv.
I have sound but no picture. the menu works so the bulbs are good.i have tried both coaxal and audio video cables with vcr also but no picture just sound.i have checked all parental locks and they are off.please help it is my only tv. thanks.my tv is not on the list so it is model # vs-5005r
50 inch rear projection tv
4 Suggested Answers
6ya staff
SOURCE:
ken black
  • 179 Answers
SOURCE: mitsubishi rear projection tv
you have a problem on the chassis. either the FMT, DM, or the terminal board have gone bad. the quickest most effective way to repair would be to repair the chassis. check out www.tv-techs.com
Posted on Dec 29, 2008
ltfrc
Mike Schmidt
  • 227 Answers
"r" usually means resistor if they are burnt it will be hard to identify the band colors on them for thier rating. Depends on if they are quater watt, or 1 watt the diameter size and where they are locted in the circut if its afffecting your picture power. If they are loose from the board means it over heated, resolder may help.
Posted on Jan 05, 2009
Chris Jowsey
  • 208 Answers
SOURCE: Will my Wii play on this?
Yes, should hook up alright
Posted on Mar 19, 2010
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Has no sound
You clearly could have a audio problem in the set but:
Look in set menu to see if speakers are turned ON or OFF.
Look at set and a cable,sat box or receiver to see if sound is turned low or muted etc.
See if set has sound when a DVD etc is imputed to the rear audio/video jacks--if it works that way the set is good and you have a problem with settings somewhere.
A last resort is most of the Mitsubishi sets have a hard reset done by entering a hidden menu with the remote--sets everything back to factory original.
Apr 30, 2012 | Mitsubishi WD-62526 Projection TV
Have picture but no sound
Go through the setup menus on your TV, and look for Audio. Some TVs are set for a rear output by default, rather than using the speakers built in.
If menu choice is correct, check your cables (if from external device). If you are using S-Video Connector, you will need to run audio cables as well. S-Video only carries the video component. If you are trying to use optical, then you will have to go back to the audio menu, and choose the format that the external device is using. If a HDMI cable is being used, try a different cable.
Sep 10, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi VS-55609: No video/audio - just static
You are on the right track. If you cannot see a picture on either antanna A or B then the tuner is suspect.
You may try hooking the cable straight into the TV if you are using a cable box, if not then you should be getting a picture when your other video devices are turned off.
The fact that you get a picture on video tells me that the AV circuits are fine.
Thanks
asnowman
Jul 25, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Tv has audio but no picture. tv was working perfectly fine last night with audio and pic but now no picture
kindly check ur video cable if ur r useing audio/video cables for you tv
if not u need to check for ur tv tube
Jun 04, 2010 | Mitsubishi WT-46807 46" Rear Projection...
WD-52525 52 in. Rear Projection HDTV Television: my mitsubishi projection tv has a distorted pictur...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My Toshiba 50 A 50 rear projection has great sound but no picture. Can you help tell me if I need a fuse or bulb?
This TV does not use a bulb. It is a Picture tube type set.
*No picture but there is a dim background. Menu works.
This is caused by a bad signal. Perhaps the video cable is bad if you use a cable box. The HDMI cable may not be working right. Try a new cable.
*No picture, no menu
This could be caused by a failure in the part that draws the picture up and down (The vertical). Can also be the side to side (Horizontal) or a high voltage problem. The last usually kills the sound as well so its not as likely.
If the cable does not fix it, you will likely need a technician.
Mar 21, 2010 | Toshiba 50A50 50" Rear Projection...
No HDMI audio at all.
Could be lots of things, from bad cable, to your laptop no outputting sound, to your tv not functioning properly. A work-around might be to use the VGA output (and sound output) from your laptop until you can resolve it better.
Jul 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Dec 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
