Haven't been used in a couple years but worked perfectly fine yesterday and today it wont turn on at all. There was a lot of dust in the back so i used a blow off duster to remove all the dust and still didn't work, unplugged the power cord and plugged it back in and still nothing. Opened the back to check if any parts were out of place and everything was fine.
SOURCE: my panasonic cinema vision hdtv model # pt-47wx49
Does the power indicator blink? If so how many times does it blink?
SOURCE: Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
SOURCE: Panasonic PT-47wx49E
It worked before on a different set see if r517 is burnt if so replace it with a 10k carbon 1/4 watt resistor.
SOURCE: Panasonic PT-45LC12......won't turn on
Its ballast supply issue that need to be replaced/ repaired.
Ballast supply drives Lamp in TV.
SOURCE: My Panasonic PT-47X54J turns on when the power
Three blinks is short protection. 98% of the time in this model it means one of the two convergence IC chips has shorted and is bad.
There is a easy way for you to confirm this: inside the set with it unplugged look for the two STK-392-110 chips this set uses--they are black in color--2 1/2 wide and 1 1/2 tall and on metal heat sinks with fins side by side.
They will have the STK-392-110 NUMBER printed on the front of them in white letters. In front of them are about a dozen light blue colored resistors--most will be marked 2.2 ohms---look to see if ANY of them are discolored or slightly white in the middle--if you find even ONE discolored you have found your problem.
Both chips and any bad resistors need to be replaced and the set adjusted with the Panasonic remote.
I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET.
The instructions tell you all that you will need to do the repair and I can tell you the best seller on Ebay to buy the chips from. This repair takes about a hour or so to do----I have done hundreds of them.
You can buy all the parts for this repair for less than 30 dollars--shops are going to get 300 or more for this repair.
If you have questions or want the instructions rate this solution as I do this here for FREE.
SD TECH
Testimonial: "Thanks for the quick, helpful response. I certainly will follow this up and would be grateful for any additional help you might be able to give."
