353092020580676 help me pleez this is the imei
my nokia 5310 has a phone locked. i don't remember my code. please help!! my imei # is : 355745020483369
Pin blocked enter puk code
Check this
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal
strength, better signal reception. It also help if u want to use GPRS
and the service is not responding or too slow. Phone battery will drain
faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart.
Increase battery life by 30% because phone receives less signal from
network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol
up(arrow keys) for 3 seconds, should say pin code. Press C,then press *
message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user
groups) to 00000 and ure phone will sound the message tone when you are
near a radar speed trap. Setting it to 500 will cause your phone 2 set
off security alarms at shop exits, gr8 for practical jokes! (works with
some of the Nokia phones.) Press and hold "0" on the main screen to
open wap browser.
Thanks.
thx so much for ur respond, but there is the security code that i need first to be able to get to the home screen. when i turn on the phone it asks imediatly for that code that i don't remember. my imei # is 355745020483369
just to say * or # is not part of this code
hey when i turn my phone on it come up security codes i dont no the code would u be able to help me plz my ime number is 352072026133416 thanks
