Akai LCT2785TA 27 in. LCD Television Logo
Anonymous Posted on Nov 06, 2012
Akai LCT2785TA - Where is the inverter?
My Akai LCT2785TA TV turns on, audio works, just no picture. If I shine a light on the display, I can very faintly see the image. Much googling tells me I likely need to replace the inverter. So, I opened the back of the TV, and, I'll be honest, I don't understand where the inverter is. I can see what I believe is the power control board and the main board, but no inverter. Can anyone help or do you know where I can find a diagram? Thanks.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
181
Points
Hay the inverter board is under the subframe that the main and power boards are mounted to.You have to remove the main board "big long board in middle" NOTICE the cable,top center of main bord wich runs under main board,wich is connected to the inverter board! So becareful when lifting the main board.After you have removed the main board.Remove the screws around the sides of subframe.Unplug cables as needed.Hope this helps. NoSugarTonight
Anonymous
Level 3:
Top Expert:
  • Akai Master 14,553 Answers
  • Posted on Nov 06, 2012
Anonymous
Akai Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718509
Points
48227
Diagrams are not to be found for most modern sets as they only sell boards---
google the model with "parts" to locate the board which in most cases will have a photo of it---then you know what to look for
  • Anonymous Nov 06, 2012
    I've already done that and know what the inverter looks like for my model. However, it must be in a non-obvious location because I don't see it after removing the back and yet another panel that exposed the main board. There's yet another level of casing where I believe there are more boards, but I'm hesitant to fish around to figure out how to get in there. I'd rather know what I'm looking for and know the way I'm going about it is the correct way.
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on May 08, 2008
SOURCE: Akai plasma tv 5 blinking red lights PDP4298ED
Have you guys checked out my solution in the troubleshooting and support for this same Akai model?
A
Anonymous
  • Posted on Aug 01, 2008
SOURCE: i need help tv lcd akai model lct2785ta
You do know that this model TV takes about 5-10 seconds to come on after you press the on button, right?
Press it once to get the green LED, then wait. If it doesn't display the blue AKAI splash screen within 15 seconds, the TV is not working as it should.
Also remember that this model has two RF input jacks. As seen from the back of the TV, the jack on the far right is the one to use for analog TV, analog cable, coax out to TV from a cable box, or rf out from a vcr.
Don't use the one on the far left. It is for input to the ATSC OTA DTV tuner only.
Most likely there is a real problem with your TV, but in the video, you are pressing the on/off button in rapid succession. That will never work with this model.
Jaime Hernandez
  • 2351 Answers
  • Posted on Dec 30, 2008
SOURCE: Akai LCT2785TA Capacitors blown out
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Anonymous
  • 8197 Answers
  • Posted on Jan 18, 2009
SOURCE: Need user manual for AKAI 27" LCT2785TA OR LCT2785TE
Here you go.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck
Anonymous
  • 367 Answers
  • Posted on Apr 06, 2009
SOURCE: Akai LCT2785TA troubleshooting
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Tv was working fine turned it off and when i turned it on all i have is sound on picture
Most likely you have a bad inverter PCB. The inverter lights the backlights so that the LCD portion can be viewed. Shine a bright flash light very close to the front of the set while it is on and look very closely for a picture around where the flash light is. If you can see any little bit of picture it is the inverter. If not the LCD panel is bad. Thanks for using fixya.
1helpful
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
3helpful
2answers
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this...
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this problem
AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
4answers
I have Akai 37" LCT TV. When I turn it on, no picture is getting displayed.
I NEED A INSTRUCTION MAUAL FOR THIS Akai LCT3701AD 37 inch Flat Panel LCD HDTV with Built-In DVD Player, ATSC Tuner and HDMI THANKS BLUE
Sound but no picture on a akai lct3201td
There could be 2 failures with your TV:
1. The power supply might no be providing 24 volts to the back light inverter board or the voltage is low.
2. If the voltage is normal then is more likely a defective back light inverter board.
The best way to know if you have a back light inverter problem would be to shine the light from a flash light near the screen and observe it from a 45 degrees angle and you should be able to see a fainted image. No image at this point might mean a power supply failure. If the image is there but fainted, then the back light inverter board is defective.
Let me know if you require further assistance.
No picture
Are you sure you replaced all of the bad ones?Did you look at the top,and bottom of all the capacitors?Can you see the picture if you shine a flashlight on the screen?Did you replace any capacitors on the inverter that lights up the bulbs for the backlight,or just the ones on the power board?I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
ur inverte is bad.  just replace ur backlight inverter,no more problem
I need help tv lcd akai model lct2785ta
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
