Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Jan 05, 2009
Sears garage door opener problems
All of the sudden our Sears garage door will open by itself, when no one has pressed either the reomote or wall unit. Then one night when coming home we pressed the remote and the door would go about 3/4 of the way up and then come right back doen. It would do this everytime we pressed the remote or wall unit. I unplugged the wall unit that I think is the sensor, as the opener itself is plugged into the celing. We were finally able to get the car in the gargage. But all of the sudden a couple of days later the door goes up all by itself then comes right back down. Now I am afraind we won't be able to get the car out of the garage without it coming down on the car. I unplug the wall unit again and will still use wall button then use door to get out of the gargae. I am hoping this will work. Any ideas on why it goes all by itself and then won't stay up
Thanks
  • fifte6chev74 Jan 07, 2009
    my garage door opens by its self. i have unhooked wires to wall button and still does it. i have changed the code five time. at night door closed,get up in morning and door is open. motor is three years old.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2301
Points
We had the same problem.  open the unit and checkt the connections.  we had a few loose wires and every time there was a vibration whether a low flying plane or a truck nearby the door went up.  My husband found a few of the wires had loosened up.
1helpful
I pulled the emergency cord on my Sears/craftsman. How do I reset it?
I predict that you pulled the cord due to power outage. After power is restored you can reset it by having the door in the open position and pressing the wall button to open the door with the opener. It should re-engage by itself if it is properly set up.
I have a Craftsman ( Liftmaster) door opener that all of a sudden one night opened our door by itself. I closedd the door and in a few minutes it opened again. It continues to do this at random times. I...
Make sure it isn't the wiring to the wall console by removing the connection at terminal #1 on the end of the motor unit. Staples used in installation can cut through the insulation and cause this problem.
Master lift remotes suddenly won't work. Wired panel button works opening and closing door.
Make sure the light in the wall control is not blinking. If it is press and hold the lock button on the wall control for 3 seconds.
R garage door opener model 139.53640srt -remote car openers wont work suddenly. have to open using the house opener, whose light is blinking
Press and hold for 3 seconds the lock button on the wall control. The light should stop blinking and your remotes should now work.
3helpful
2answers
Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
2helpful
Garage door opener flashes quick green code?
The end is near. No just kidding. It sounds like your opener is in 'lock' mode. If you have the wall control with 3 buttons, press and hold the button with the lock icon for 3 seconds. The flashing should stop.
1helpful
Garage Door Remote Openers Stopped Working Suddenly
Check the wall control. If the small green light is blinking press and hold the button with the lock icon for 3 seconds.
Need to convert Sears Craftsman (953678) garage door opener remote to Lincoln Navigator built in remote.
You must push a red button on the Craftsman garage door opener then you follow the instructions in Lincloln Navigator manual. The instructions to push the red button may be on the Craftsman garage door opener reomote.
I have a Sear 1/2 horse power Garage door opener problem 41A4315-6c
YOU CAN BUY A CRAFTSMAN / LIFTMASTER / CHAMBERLAIN UNIVERSAL RECIEVER THAT PLUGS IN THE WALL.AND WIRES TO YOUR PUSH BUTTON.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
