Try this link > http://www.armitron.com/watch_instructions.asp
SOURCE: How do I set the time on my Armitron All-Sport
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"---compliments of Gene Lawson
SOURCE: setting time on Armitron 40/ 8089
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please
SOURCE: How do I set alarm for Armitron All- Sport Watch #45/6975?
Click mode once then use st/stp to cycle trough the chime (which looks like a little signal) and alarm(which looks like a little flashlight) at the top.Note (you can have both on at once)
SOURCE: I have a ARMITRON All
Hello, Turbojet2011
Armitron is great about posting their instructions online. You may want to first check out the website below. You can select you type of watch you own and download a PDF file with instructions on how to set your watch.
If you still need further help, please do not hesitate to come back here post another message.
Enjoy your watch!
--Sandy
SOURCE: set the time on a Armitron WR330 40/8125 All-Sport
Hi jerryurq51,
Please follow these steps to set the time of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
