Refrigerators Logo
Clive Townshend Posted on Nov 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Haier HRF 6631SB2/U refrigerated water light red
Haier HRF6631SB2/U fridge freezer- refrigerated water light normally blue now shows red
Hilary M
Level 2:
Novelist:
  • Expert 169 Answers
  • Posted on Jan 22, 2023
Hilary M
Expert
Level 2:
Novelist:
Answers
169
Questions
0
Helped
46659
Points
317
If the refrigerated water light on your Haier HRF6631SB2/U fridge freezer is showing red, it could indicate a problem with the water dispenser. Here are a few things you can try to fix the issue:
  1. Check the water supply: Make sure the water supply to the fridge is turned on and that the water supply valve is not closed or clogged.
  2. Check the water filter: Make sure the water filter is not clogged. If the filter is dirty, replace it with a new one.
  3. Check the water inlet valve: Make sure the water inlet valve is not clogged or damaged. The valve may need to be cleaned or replaced.
  4. Check the water dispenser line: Make sure the water dispenser line is not clogged or frozen. If the line is frozen, defrost it.
  5. Check the control board: If the above steps do not resolve the problem, the control board may be faulty and will need to be replaced.
If you are not familiar with any of these steps or if the problem persists after trying these solutions, it's best to contact the manufacturer or a professional for further assistance.
3 Related Answers
Anonymous
  • 3600 Answers
  • Posted on Jul 09, 2009
SOURCE: Water Filter Alarm Light
TRY to unplug for 5 minutes and replug it back in that should clear the code and if it does not repost a comment it here to fix it. Hopes this
fix the problem. Avid101
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Dec 19, 2010
SOURCE: freezer wont stay cold, refrigerator
There are so many different things that could cause this I will need someone to look at these things.Click Here=> GE/Artica Technical Information If you are able to follow these items to check I will be able to point out what is most likely. First open freezer and look at rear wall to see if there is a frost line building up. If not then unplug and at link above click on wiring diagram and it will open into a new tab as a Service Manual, Save to disk. Have you tried to get the temperature board to respond to lower temperatures? If not responding I will need someone to do some voltage test from tech. sheet at site above. Your compressor could be short cycling also due to defective start relay, capacitor or defective motherboard Part=> WR55X10942 I know I can help you fix it if you feel comfortable with checking a few things. The defrost heater is part=> WR51X10055 Defrost Heater Assembly The part for defrost thermostat=> WR50X10054 Defrost Thermostat Either way it is a defrost problem or a control problem and the compressor is very likely getting hot from struggling with trying to cool. Tell me the answer to the first item above and we can both find exactly what is happening, Thanks Sea Breeze sea_breeze_33.jpg
Anonymous
  • Posted on Jan 06, 2011
SOURCE: E522B bottom freezer Ice maker not working. Red
the ice is just freezing in the bottom of the bin in a solid mass
Haier refrigerator hrf-628af6 ice tray stuck cant release from fridge
If the ice tray in your Haier refrigerator is stuck and you're unable to release it from the fridge, there could be a few different issues causing the problem. Here are a few things you can try to fix it:
  1. Check the ice maker arm: Make sure the ice maker arm is not stuck or broken. If it is, it will need to be repaired or replaced.
  2. Check the ice maker mechanism: Make sure the ice maker mechanism is not jammed. If it is, try to unjam it by gently pushing or pulling on the tray.
  3. Check the temperature: Make sure the freezer temperature is cold enough for the ice to freeze. If the temperature is too warm, the ice will not freeze properly and may become stuck in the tray.
  4. Check the water supply: Make sure the water supply to the fridge is turned on and that the water supply valve is not closed or clogged.
  5. Check the water filter: Make sure the water filter is not clogged. If the filter is dirty, replace it with a new one.
  6. Gently try to move the ice tray by pushing or pulling, if it still won't come loose, it may be best to contact the manufacturer or a professional for further assistance.
Please note that some models of the refrigerator have a release lever, check the owner's manual to locate it.
How can i operate the temperature of the haier fridge model hrf-660aa
do you hear the compressor come on? can u feel it vibrating? if not? bad relay maybe? is there power from the outlet? may also have a bad cold control thermostat or defrost timer? is ther any heat in the freezer compartment?
Defrost timer location
Check this out for manual: www.manualowl.com/p/Haier/HRF-588FR/Manual/99803
Haier defrost timer location Refrigerators hrf-350
Sir i have haier refrigerator hrf 368u its freezer is working making ice but lower portion is not working properly. it is a direct cooling system without frost free
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Top freezer is workiing fridge is not haier preference series htp 18 gaa
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
How Do i have a Haier HRF-388AE, Do you know how to defrost the Freezer while leaving fridge on?
CAN'T BE DONE AS THE FRIG WORKS OFF THE FREEZER,THE FREEZER MAKES ALL THE COLD AIR FOR FOR FRIG.IF IT'S NOT FROST FREE JUST TURN THE THERMOSTAT OFF TILL FREEZER IS DEFROSTED,IF FROST FREE YOU SHOULD'NT HAVE TO DO ANYTHING,HOPE THIS HELPS-MIKE
Haier HRF-488FR/***
hi there, i noticed your post was in 08 did you find a seal to fit your fridge i have a hrf 488 fr/a and fisher and pykel are looking after them now... they advised be that this model is obsolete now and no longer have parts available.
2helpful
2answers
Leaking water INTO fridge
Your problem is a blocked drain which prevents melt water from the defrost from getting out. You'll have to expose the coils and find the drain hole. It is possible that the problem can be on the other end of the hose...where it hits the evaporation pan in the bottom of the unit.
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
