Originally it wouldnt eject even with the pin, we downloaded the update and used a lense cleaner and it is now almost fine except for continuous random looping making it impossible to mix, please help!
This probably means that one or two of the tact switches which enable the loop (loop in, loop out, reloop) is damaged and need to be replaced. In pioneer cd players when a tact switch is semi-broken, then if you press another button then it looks like you pressed that semi-damaged switch. For example you may hit "cue" and the cdj loops! It is quite common.
If you have some soldering skills this is the tact switch:
http://artaudioparts.com/product/dsg1079/
SOURCE: cdj 800 keeps skipping
Does it keep skipping, or does it keep looping? 2 very different things. If it's skipping, it will sound like it's scratched, and will only skip on some CDs, and not others - unless your tray is messed up.
- Davis
DJ Pro Audio
www.djproaudio.com
www.djprolab.com
www.1200s.com
SOURCE: Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
SOURCE: Model:Pioneer CDJ 800 MK2 , problem of eject the CD
Hey i just had the same problem im form denver colorado my cd wouldnt spin or the laser would not move then it wouldnt eject it i took it to this place called downtown radio and i tought they where gonna need to get some parts from pioneer the problem was that the IC Protector IC protectors are a type of solid state fuse often seen in consumer electronic equipment.http://freespace.virgin.net/matt.waite/resource/handy/icprotector.htm look at this site and the show what they look like its the N type there about $1 or $2 they fixed it for me and they charged me 130 so look around and find out what they are and try to find it in the cd deck its really small!!!!!
SOURCE: pioneer cdj 800 mk2 needs new cue button needs to
PART NUMBER IS DAC2059 This also includes the play button.you can order from pioneer parts on line
SOURCE: A drunk chic spilled some of her mixed drink on my
wipe it up using moist damp cloth ,slightly soapy, and invite her back to help you,
