Question about Garden
On the atom edger where are the positions of the fuel lines. Bought one with none on them. Any help will be great. Thanks
  • 430 Answers
Looking at yuor video the fuel line coming off the top of the carb goes to the short spout on the primer bulb. The long spout on the primer bulb should return to the tank and terminate inside the tank. The main fuel line should use the other hole in the tank and is an assembly consisting of a filter that fits in the hole and seals with a plastic washer on the outside of the tank and goes directly to the spigot on the bottom of the carb ( in the video this spigot is visible and does not have a fuel line attatched to it)
Posted on Nov 05, 2012
6ya staff
SOURCE:
Rubber plug petrol tank for atom edger mod.101. 102 thanks
If you're referring to the grommet where the fuel lines enter the fuel tank, just go into any mower shop and ask for a Ryobi tank grommet. It is effectively a generic item and is interchangeable with almost all 2 line grommets.
Alternatively, as an Atom dealer, I could order the genuine part in for you.
Jun 19, 2018 | Garden
Where to get replacement fuel line for edger
Your local hardware store and ebay has a great supply as well.
Apr 20, 2014 | Poulan Pe550 Gas Edger
How do you replace the fuel filter on a Weedeater PE 550 lawn edger?
You can find replacement fuel filters at a nearby hardware store. Once you have one, fish out the line from inside the tank and fit new filter onto line and place it all back into the tank. You will probably have to back out the tube a little after re-installation.
May 01, 2012 | Poulan Pe550 Gas Edger
I just bought 15 cans unopened of atom 8018 c-1 What is it good for? Should I try to sell it? Thanks
#1: Atom arc rod is very good and expensive rod comparatively speaking. 8018 is similar to 7018. It is an all position rod but instead of 70,000 pound tensile strength , it has 80,000 pound tensile strength.7018 is commonly used in repairs or steel construction 8018 is used in appilcations where the need for a higher strength or stronger weld is called for . Usually when welding higher grade steel than A.-36 It can be used in place of 7018. 5/32 calls for 150+ amps. 1/8 is a more common size.Remember Atom arc is top of line but finding someone who will pay the difference or needs this rod may be hard to find.
Mar 03, 2011 | ARC Atom Arc 8018 532" Welding Rods 38 Lb...
Fuel starvation on Husqvarna 322l trimmer. Has run great for 10 years this year but now starts great but then rps drop and it shuts off. Pump the primer a few times it will only run on the fuel from the...
Gunner, you may want to;
inspect the lines for pinches or cracks,
clean or replace the fuel filter
replace the carburetor fuel pump diphragms/gaskets, and inlet needle
remove any adjustment needle for cleaning with a spray carb cleaner
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 08, 2009 | Husqvarna Garden
On my craftsman gas edger, the fuel tank has 2 holes on bottom, my fuel lines broke. i bought new lines but how do you install the lines do you put a fuel line in each hole or do you use tine same line and...
Hi ken If your machine has 2 holes in the tank it must have a primer first of all you you must fish out the pick up filter from the tank feed your new fuel line into one hole and out the filler hole connect the filter & put it back in that line goes to the bottom of the carby the next one from the top of the carby to the primer then from the primer back to the tank.
Jul 10, 2009 | Garden
Wont run in run position
if it runs on choke only and it sat up for two or three months the carb diaphragm may be brittle and not pumping fuel. install a carb diaphragm and gasket kit or try opening the high speed jet a 1/4 turn
Jul 01, 2009 | Craftsman 25cc Gas Line Trimmer
Replacing fuel line
Have you removed the carb. and tried to clean it? If not, get the numbers off the carb. and pick up a repair kit for it. Dismantle it, clean all orifices, remove the low and high speed needles (may only have one and count number of turns each one is at by screwing in until lightly seated then remove ) and clean passages with carb. cleaner. Reassemble, install, adjust initially with original settings and start. Adjust from here. Little carbs. are very "touchy" when adjusting.
Mar 08, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
157 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
