Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
No water going into o matic ice maker - Ice-O-Matic ICEU220HA Undercounter Ice Machine
    New Friend:
    Problem Solver:
  • 5 Answers
Check the water float that is how the unit deterines when the reservoir has enough water it could be stuck
Posted on Feb 17, 2013
2 Suggested Answers
6ya staff
SOURCE:
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: ice maker is working, but there is water in the bottom of bin
You will need to pull out what ice you have in the bin to get to the drain. Once you have done that, take a hose and force water thru the drain. You may have to snake the drain if is more than a build-up of ice. Once the drain is working, clean out the bin with ice machine cleaner and sanitizer. Restart the machine and make sure no water is dripping from the evaporator above. If there is, it needs to be cleaned.
Posted on Jan 17, 2010
Ice machine won't fill with water
Make water supply is on if you have a water filter in place it may be clogged or if unit has a float valve youmay has trash in the line clogging it up
Apr 02, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice does not make completly in cycle
be sure your water level sensor is not corroded and dump valve not leaking
Apr 02, 2014 | Ice O Matic Complete Units ICE0250FA Cube...
Water keeps overflowing out of the sump trey continue running
Replace water fill float valve is letting water seep buy during freeze cycle and it will not make ice due to water too warm
Jul 26, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Whirlpool icemaker
If this an under the counter ice maker the machine is going to run water all the time with the exception of when the ice slides down to the cutting grid to be dropped.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 05, 2012 | Refrigerators
No ice in my ice o-matic model ice220ha1
no water entering ice forming tray
no/low gas charge
hot gas valve stuck open
no sprayer pump working or paddle wheel drive motor not working
Apr 01, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice maker is working, but there is water in the bottom of bin
Nov 07, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice-o-matic wont' drain water from bin
the purge valve empties the tray... the bin just drains with gravity... If you bin isn't draining... it must be clogged somewhere.
May 23, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
171 people viewed this question
Top Ice Kitchen Appliances - Others Experts
Joe Palazola
jasbo
jasbo
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
