Playing back our homemade VHS tapes, on two different machines, we see what looks like tracking/speed problems - on our JVC player, which shows speeds, the ''EP'' becomes ''LP'' during these brief, very frequent noisy periods - the tapes have been stored for several years in our basement - this problem does not appear to happen on the commercial VHS tapes we have (which have been stored upstairs)
The problem is dirt, dust or even mould on the VHS tape. You should look on youtube for video's about cleaning a VHS tape. However if it's really bad there is nothing you can do about it. Commercial VHS were only recorded on SP so the quality of the tape means more signal, so less of a problem keeping the video tracked, even if the tape has patches of mould, likely if kept in a basement!
SOURCE: My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
SOURCE: JVC HR-XVC26U will not fully
Th e processor is confuse because of the garbage it has in it, and if you leave the the VCR unplugged from the wall for 40Min., it will reset back to normal.
SOURCE: I've had a DR-MV5S DVD
Register and download the manual for free audio.manualsonline.com http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it? Solve the load or playback problem and it will probably record. Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
