Question about Toshiba SD4990 DVD Player
Rotor doesn't stop after insert DVD
After I put DVD into player. It started, but it seems cannot find the start of DVD, so rotor keep spining, won't stop. Thanks. Pete
    Guru:
  • 104 Answers
Its seems that DVD player can't read the DVD. Can be: 1. DVD Player eye is dirty 2. DVD format on unknown to DVD player There are kits that clean DVD player eye, I would try it first.
Posted on May 19, 2007
6ya staff
SOURCE:
Won't fill, spin, rinse, drain
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
How do i separate the engine from generator on powermate 5000
It generally has a long rotor through bolt accessibile from the generator end, this forces the generator rotor onto a tapered shaft on the engine. Once removed the through bolt slide a long bar ion the hole and screw the bolt back in, that will force it off the taper
Oct 29, 2012 | Coleman Powermate Portable Generator...
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
My 1994 Jeep grand cherokee won't start. It tries to start but doesn't. Tried replacing cap and rotor and still will not start. When I checked the spark it was yellow. What does that mean?
Yellow means weak spark should be blue check the coil tower where the coil wire attaches on the coil for corrosion. Also check the spark plugs for wear.
Feb 03, 2012 | 1994 Jeep Grand Cherokee
Pulled distributor on 97 chevy truck v6 and cant seem to get it back in right! wont start! got it to top dead center many times! they say put rotor to cyl #1 but do they mean #1 in cap or face rotor to...
when the engine is a top dead center on cyl one put the distributor in so the rotor points to the no1 spark plug wire trminal on the cap try that let me know if it helps
Jan 16, 2011 | 1997 Chevrolet K1500
Steering all of a sudden starts, now forgive me, "goes back and forth, by itself..." when i came to a stop, full stop with foot on brake, the steering wheel "goes back and forth" by itself...seems to...
One of two things has happened. You have a damaged wheel / tire assy. One of the wheels is bent or the tire has a bubble. Or you have a warped brake rotor. Most likely it is a front rotor - but can be any one of the four. To ck for a bad tire wheel assy. Jack up the car each tire one at the time, and spin the tires looking for a out of round side to side motion. Also at the same time you can ck for a warped rotor by spining the wheels and have some one easy step on the brakes if you feel one spin free then lock up then spin free that is the bad rotor.
Oct 17, 2009 | 2006 Chevrolet Malibu
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Toshiba SD4990 DVD Player Logo
590 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
