Neff U1421 Double circotherm Electric Oven Logo
Andrew sings Posted on Nov 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Neff double oven trips rcd when either oven is turned on
Clock display is ok but as soon as either oven is turned on rcd trips on consumer unit
Jason Harris
Level 2:
Sergeant:
  • Expert 274 Answers
  • Posted on Nov 03, 2012
Jason Harris
Expert
Level 2:
Sergeant:
Answers
274
Questions
Helped
89608
Points
648
Your heater elerment has gone in the main oven i had the same problem if you need help takeing it out and see if its the problem get back to me ok
5 Related Answers
Anonymous
  • 8197 Answers
  • Posted on Dec 19, 2008
SOURCE: fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 03, 2009
SOURCE: Oven has stopped working
The main oven element has failed, you need to fit a new element.
If you remove the rear cover in the oven , you will see the element.
Disconnect and replace. Be care ful not to lose the wires behind the aperture.
Plz rate my solution.
Thanks.
Anonymous
  • Posted on Nov 02, 2009
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 23, 2009
SOURCE: We have a NEFF AP54-8 double oven which trips as
If it is an electric`fan assistred oven, then the problem is more than likely due to a faulty oven element.
To replace it, you will find it located at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
arepairman
Richard Saupe
  • 20 Answers
  • Posted on Mar 14, 2010
SOURCE: MY NEFF DOUBLE OVEN IS ABOUT 8 YEARS OLD I HAVE
it sounds to me that the fan is not working properly. as the oven gets older the fans become weaker and then doesn't blow air over the element at a rate that can the temp down enough..
regards
Richard Saupe
http://www.saupe.co.uk
Oven Specialist
Neff U1422 oven grill tripping RCD
The grill element has an internal short and needs replacing. Sometimes you can see it as a slight bulging of the element. This happens just before it blows a hole. It may also have been physically damaged when something was put in there after a few Sherries. :>D Sounds like your RCD is adequately sensitive.
Jan 02, 2024 • Neff Ovens
I have a eurolec double built under oven. When I turn the bottom oven on the rcd at the house consumer unit pops. The top oven works fine...
The elements in ovens consist of an outer earthed metal tube and an inner resistive element that is insulated from the outer tube by what is effectively a compressed ceramic insulating powder. If the element is not used for a while, enough atmospheric moisture, (or from spills, etc), can penetrate the insulation to cause enough earth leakage to trip the RCD. If the RCD is tripping at the correct level, (They can get too sensitive - see this article here:
Diagnosing RCD earth leakage breaker nuisance trips), then the only long term solution is to replace the element, although they can sometimes be dried out by heating them.
Aug 11, 2014 • Ovens
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
1helpful
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Keeps tripping out rcd 63 amps when warming up after about 10 minutes
If your oven is rated above 14kw then change the RCD to 80A. But if its rated less than this then please check shorted element and change them
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
1helpful
2answers
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Thanks.
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
