We replaced the fuser and now when I turn on the printer, the top screen reads "843.00 Service s" and on the next line "an". Not sure how to go about fixing this problem.
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
SOURCE: 123 Service Fuser Error - Lexmark C762 Colour Printer
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
SOURCE: Lexmark C772n - 127.07 Service fuser error
I searched the Technical Manual and there is no explanation of the code. The user manual simply says there is a printer failure. They ask that you turn the printer off, wait 10 secs and then restart. Then call 1-800-LEXMARK and they will tell you about the code.
Given that your printer is saying Service Fuser, it is highly likely the fuser is ready for replacement. The fuser is the component that heats to high temperature to fuse the toner to the paper and complete the print cycle.
SOURCE: I have a Lexmark T644 that has a 922.34 service
Please follow the appended link to the Lexmark Technical Support website.
Don
http://support.lexmark.com/index?page=answers&startover=y&question=83.05+ITU+Missing+error+message&locale=en&productCode=LEXMARK_T644&segment=SUPPORT&userlocale=EN_US#2
SOURCE: I have an x543 Lexmark printer and there is an
i have an x543dn has a fuser error of 122.03 service fuser error, i just reset the factory defaults in the config menu and it cleared that error, to get to the config menu press and hold the tick button and the right arrow next to it then power up the machine and continue holding these until the menu is displayed then scroll through menu until you get to factory defaults select this then select reset base, hope this helps. Kev
