Hi, You can get the network unlock code for a Samsung E2120 from www.classicunlocking.com/samsung-e2120/rs16wp9/ at low cost.
UNLOCKING STEPS FOR SAMSUNG E2120
Method 1:
1 - Switch ON your Samsung E2120 with a NOT ACCEPTED SIM Card.
2 - Samsung E2120 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung E2120 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung E2120.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: means to use a sim card from a network other than the network your Samsung E2120 is locked to.
CODE: Its the unique Unlock Code for your Samsung E2120.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung E2120.
SOURCE: how to put music on samsung gt e2120
I bought the e2120 for a friend this week and have put the 2 gig micro SD card I purchased separately into the phone, (it goes in the slot next to the sim card under the battery). You can put the memory card into your computer with the SD adapter that comes with the micro card and put photos and music onto the card that way. However, I am having trouble getting the phone to recognize the music that I put onto the card. I am not sure if I used the right mp3 format, so I will check. Anyway in my search for an answer to this problem, I ran across a couple of forums where your problem was addressed. You can connect the phone, (with the micro SD card inserted into the phone as I said above) then buy a USB cable to connect the phone from the charger slot to computer. Your computer will recognize the phone SD card as mass storage. Then you can drag and drop the files you want from the computer to the phone storage card. Just be sure the files you want to use are the right format to be read by the phone’s software, (e.g. jpeg for photo and mp3 for music). Then you can go to the storage card menu on the phone to find the files. The USB cable they said you need is called …
APCBS10BBE
See http://www.mobilefun.co.uk/samsung-usb-data-cable-p14710.htm for a list of phones supported
Other file transfer instructions from another site are…
samsung e2120 has file transfer capabilty. instructions are as follows:
connect data cable from device to pc > press menu > select settings > select pc connection > select mass storage > drag and drop your files.
Hope this helps.
SOURCE: hi i have a samsung GT-E2120 and it has a virus so
My Samsung gt-e2120 phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only way to stop it is to remove the battery
SOURCE: My Samsung GT-E2120 phone won't
My Samsung GT-E2120i phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only way to stop it is to remove the battery.what do I do to solve this?
the problem is as a result of software corruption. Your phone operating system is corrupt for one reason or the other. The phone operating system might have gotten virus through bluetooth transfer, internet browsing or via the memory card.
To solve the problem, you need to flash the phone. Flashing the phone means reinstalling the phones operating system software files. The phone will be fully formatted and a fresh operating system files will be reinstalled.
I don't think you will be able to flash this pone yourself because of the tools involved. You will be needing the phone's flashing cable, flashing software and a computer.
Phone experts are the ones that have this software and cable for various phones.
Therefore, I would suggest you give your phone to a phone tech to help you fix this problem. The phone tech will help you flash the phone and your phone will be perfect again.
I am recommending you to a phone tech because this is not what you can do yourself.
I hope you understand this.
Good luck.........
