Kenmore Elite 45986 Front Load Washer Logo
Posted on Jan 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting an DL F code on my front loader
It use to be a f11 code problem and now it is a DL F code problem. Does anyone know what that means. I have unplugged it for hours and I am still not able to wash anything.
Anonymous
Level 3:
President:
  • Master 373 Answers
  • Posted on Jan 04, 2009
Anonymous
Master
Level 3:
President:
Answers
373
Questions
Helped
192824
Points
1748
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
  • Anonymous Jan 04, 2009
    F11 is a serial communication error. Could be as simple as a loose or
    faulty wire harness, bad drive component or more complex like a failed
    MCU, CCU or even the motor. I wouldn't rule out the door lock assembly
    either.
3helpful
2answers
We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
I have an E4 front loader it is flashing F11 what does that mean?
If you're handy, there's a guy on Ebay who seems to specialize in the F11 problem. Here's the web address:
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2
I know nothing about him, but he has great feedback.
2answers
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
What do i do when it says dl?
usually when it is clicking when it fails and gives you an f11 error code. This means you have a fauly ccu board. it is a communication error between the computer and the door lock. I am 99% possitive you need a new controller.
Door Lock Problem
with panel off reach up to lock location pull down on small tab door latch will click (at this point door would pop open if it were closed ) retry operation to see if ok if code dl reappear may to replace door lock if f11 may need new control module under top rear..ck wires first ..good luck
Error F11
Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Works for certain machines, dont see why it wont for yours.
1helpful
F DL Error Code
If you were already experiencing the F11 error code and now experiencing the Fdl error, this more than likely is a failure of the Main Control Board. F11 is a serial communications error associated with the Main Control Board, while the Fdl error is either a failed Main Control Board and/or door latch. You can replace the door latch first to see if the error goes away, but I would almost bet you have a control board problem since you were already experiencing an intermittent error code associated to it. Let me know if you have any further questions.
Alexander
vince
