The knobs started smoking, the 1 burner popped and shut off and another burner popped and blew out green flames. Had to reset the breakers to restore electrical, but want to check wiring to knobs underneath top panel before restarting LP gas, but have lost user manual. How do you separate the top panel from the base?
SOURCE: Dacor Cooktop gas conversion
Where did you purchase the kit? Can you name the store with number or list the website? Also the part number information. Thanks
SOURCE: SGM464EM cook top valve rplacement
you have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
SOURCE: i spilled coffee in the control knob area and
DRY THE CONTROL AREA AND THE IGNITIONS WITH A HAIR DRYER .
SOURCE: I have a 5 burner Dacor Cooktop (SGM365) with
In the middle of each burner, there is a small brass ring that screws in the burner. If you unscrew all five and pull the knobs, the top should come off. From there you can access the electronics. Because all the burners ignite at the same time, I would suspect either a disconnected or shorted wire on your right burner or some corrosion has occurred at that burner preventing it from grounding properly.
SOURCE: Yest. someone spilled chili onto controls.
You need a special wrench to open the burners. Better call a pro.
www.oc-repair.com
