Question about Dell Dimension 4600C PC Desktop
My machine beeps 2 long and 4 shot times. what is the problem?
  • Dell Master
  • 32,281 Answers
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Posted on Nov 03, 2012
6ya staff
SOURCE:
3 Beep Warning
Staying in the freeze cycle too long. Usually about an hour. Several things can cause this. Look for water running even if machine is off. Possible stuck float switch. And more.
Nov 08, 2013 | Hoshizaki KM-61BAH 49 Pound Self-Contained...
How do you set time and date on schiller at2 ekg machine
HI,
To set time on the schiller AT2 do the following.
1. Power ON the machine.
2. Press the following key sequence ALT,9,1,1.
3 Now enter the time using the digit key (HHMMSS)
You will hear the conformation beep indicating that the time is seted.
To set the date on schiller AT2 Do the following.
1. Press the following key sequence ALT ,9,2,2.
2. Enter the date using the digit key (DDMMYY)
You will hear a conformation beep indicating that the date is seted.
ok
Sep 08, 2011 | Schiller Welch Allyn Cardiovit At 2...
I have a AT2 Plus machine and cannot find my manual. the time and date is set incorrectly and I would like to change that. could you please assist me.
To change the Time :
- Firstly, press the following key sequence : ALT, 9, 1, 1
- Then, enter the time (HHMMSS)
- Finally you'll hear the confirmation beep
To change the Date :
- Firstly, press the following key sequence : ALT, 9, 2, 2
- Then, enter the date (DDMMYY)
- Finally, you'll hear the confirmation beep
Jul 02, 2010 | Schiller Cardiovit At 2 Light Ecg Machine
Model a6q10f2a beeps 2 times when plugged in, and
Pull the unit from the wall and it`s shell,check the fan to see if it is turning ok by hand,if there is any restriction,it will blow the control board,the circuit board behind the controls,clean the unit while you have it out,if the fan is stiff,and does not turn,this could be the problem,and if so,the circuit board is most likely shot.Also,the circuit board is most likely shot anyway,even if the fan is fine,there is a lot of problems with fedders and other brands,and the circuit boards,they dont last too long.
Jun 11, 2010 | Fedders A6Q10F2B Q Chassis Room Air...
Acer Aspire 9303wsmi display problem, 1 long beep, 2 short. HELP!
What you hear are bios beeps. They signal you that something is wrong. These beep's vary by the manufacturer of the bios chip that you have.
You can find out what bios you have by looking at your manual. The common cause for one long and two short beeps is a video problem.
Either the video chip on your mobo is shot, or your video card needs attention.
Hank
Aug 04, 2009 | Computers & Internet
Dell precision 3100 machine will not boot up
Hi there
The beep codes indicate that there is a problem with the system memory, it may have to be changed.
Thanks for using fixya!!!
Feb 02, 2009 | Dell Dimension 3100 PC Desktop
Wahing machine
Try pushing the skip button this may reset the prog. These machines will beep to indicate a fault. Dependant on how many times the machine beeps b4 it pauses ie 1 beep then a pause would indicate the machine isn't filling, 2 beeps its not pumping out, 4 beeps doors open. Hope this helps
Nov 30, 2008 | Zanussi FJS1225W Front Load Washer
My Lenovo T60 will not boot up
ok...and these beeps..do they happen before screen shows anything?
Nov 21, 2008 | Lenovo Thinkpad T60 Notebook
Dell Dimension 4600C PC Desktop Logo
275 people viewed this question
Ekse
Clive
Clive
Alun Cox
