Whirlpool RBD306PD Electric Double Oven Logo
karen gilbert Posted on May 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need actual part
I have tried to locate the part online as well as calling parts suppliers. This model does not have a "temperature switch". Does it go by another name?
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on May 18, 2007
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898594
Points
3964
Possibly you are looiking for the thermostat
2answers
I have a GE Dual wave II Microwave System (model # jkp68g0k3). Still works great.
You may be able to find a replacement glass for your GE Dual Wave II microwave system by contacting GE's customer service or parts department. They may have compatible replacement parts available, or be able to direct you to a third-party supplier that carries them. You can also try searching for the part online using the model number of your microwave. However, keep in mind that older models may have limited availability of replacement parts, so you may need to consider alternative solutions such as having the glass custom-cut or purchasing a new microwave.
Feb 09, 2023 • GE Ovens
Hi I took apart my oven door on my atwood Wedgwood to clean in between the glass and now can't figure out how the two black brackets go on. I took them off the inside bottom to take off the glass
To help you, I need the model number for your unit--try to locate the exploded parts diagram(type in your model number and then type "parts" without the quotes) online or call the manufacturer--some user manuals have a parts breakdown
Aug 23, 2015 • Ovens
I just got a Rosieres F200T oven for free but don't know what the degree knob means since it is numbered 1-9 and not the actual temps that I am looking for. I was searching online to see if anywhere...
Hello, Timcampbell82 -
I have tried to find a user's manual for a Rosieres F200T oven for you. I suspect the user's manual states what temperature each of the numbers for the degree knob represent.
So far, I have not found a manual online for you. I did find an online forum in French, with mention of a manual for the oven model, but the messages date from 2008:
https://www.meilleurduchef.com/fr/forum/notice_materiel/1225015073-14054-650
You may wish to locate a business in your area which performs repairs for Rosieres ovens and ask if they can find a manual you can purchase for your model oven. Or, perhaps one of the repair technicians can tell you what temperature each number represents.
Best wishes.
Jan 19, 2018 • Ovens
1helpful
Error code F2
F2
During
BAKE Control senses oven
temperature above 615F-630F If actual over temperature condition occurred: Look for
welded relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
If no over temperature condition
occurred
: Look for a high resistance connection or any other cause of high
resistance in the oven temperature sensor circuit. Check sensor, sensor harness
and sensor harness connection at sensor and oven control. Replace sensor if
found defective.
Remember: Oven control (ERC) measures resistance
of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F
Look for welded relay contacts. If this happens, replace oven control (also
If no over temperature condition occurred:
Look for a high resistance connection or any other cause of high resistance in
the oven temperature sensor circuit. Check sensor, sensor harness and sensor
harness connection at sensor and oven control. Replace sensor if found
defective. Check door lock switches.
measures resistance of sensor circuit , not actual oven
temperature.
2helpful
Shutting down with an F2 blinking at us
F2 During BAKE. Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN . Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
4helpful
F2 error beeping make it stop
F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
Broken oven switch, Magic Chef gas oven
http://panjiva.com/Manufacturers-Of?q=magic+chef+spare+parts
http://www.partselect.com/Magic-Chef-Parts.htm
It;s a global economy now, and you can order and buy spare parts from anywhere for anything. please use these links provided to source your part,and ship it back to the mother land, Aoteroa.
  1. Find the model number on the appliance to be repaired. Look for a gray or silver label on the appliance that lists the model number and serial number. If you cannot find the tag, check the locater featured on PartSelect.com. Click the link marked "Need help finding the model number on your magic chef appliance?" Then click on the type of appliance. The guide will show possible locations for the identification label, along with a sample label for visual reference. The URL is listed in the resources section below.
  2. Use the part number to make ordering simple. Look closely at the part you intend to replace. A part number will be printed or inscribed on any part that is large enough to display at least six digits.
  3. Order parts from appliance retailers. Call local USA appliance shops and ask if they sell parts. If so, get a price quote for your part and ask if it's in stock, or how soon it could arrive.
  4. Order from online parts dealers. Use your appliance model number and part description or part number to check online parts dealers for prices and ship times. PartSelect.com, RepairClinic.com and AppliancePartsPros.com all sell Magic Chef parts online. The Magic Chef website may also be able to provide needed parts. It also lists owners manuals, warranty information and installation instructions for their appliances (see Resources).
  5. Compare prices and order fulfillment times between local retailers and online dealers. Most online dealers will offer lower prices. A local dealer may have to wait for your part to ship from their supplier. The shipping time between local and online dealers may not vary.
F3 f4 f8 on a ge modeljtp15wdw2ww
GE Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F2
During
During
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC). F8 Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. F9 Lock switch Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. FC Problem with door lock circuit such as pinched wires between control and door lock switches on motorized lock circuits Check wiring and test operation of switches. FD Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. Replace probe if all else checks out ok. FF Loss of door motor safety switch Replace the oven control (also called clock or ERC). FFF Control error, failed EEPROM Replace the oven control board (also called clock or ERC).
The main control operates a series of software commands, which control the various features and functions of the oven. Each function or operation has a numerical value assigned to it. The numerical values can be added up - this is called the check sum operation. Every time the system is powered up and after each clean cycle the system performs a check sum and compares the value to the value programmed into the software (stored in memory).
An EEPROM check sum error or FFF code occurs when the values differ. If this happens, replace the oven control board (also called clock or ERC).Here is a list of error codes and corrective action that should be taken. Mike
1helpful
I have moved into a house about 11 years old. I started the self clean and now about two hours into it an alarm is going off signifying "F2 door locked". Can't turn off alarm :-( Don't know part...
F2 During CLEAN The Control is senses oven temperature above 915F-930F. If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC). If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches. Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jun 03, 2009 • GE Ovens
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
