No singular answer. Here are some of the things to try, following by links depicting details: 1) Update audio drivers via device manager or 3rd party ware 2) Change sound quality by altering Speaker properties via Sound icon on task bar 3) Change Loudness Equalization of Speakers in Enhancement tab of Speaker Properties 4) Run Audio Troubleshooter 5) Use Windows Volume Mixer to increase sound 6) In Sound, change Communications tab to Do Nothing 7) Try different audio device 8) Try VLC and adjust it to boost volume 9) In Chrome, use Volume Boosting extension 10) Clean speakers 11) Increase Media Player sound
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume iconsystem select adjust volume
Adjust the volume level of the TV to low while the Logitech Speaker volume is at the middle... try changing volume of both TV and speaker to achieve satisfying results.
Volume keys: These keys allows you to turn up or down the volume of the ringtone and the speaker. Press these keys to turn the volume display on, and to change the volume. To lower the volume of the ringer during an incoming call, press the down volume key to the desired volume, or until the option changes to Vibration All Activated. The volume keys can also be used to scroll up or down to navigate through the different menu options. These keys are also used when the Music Player is active. While on call turn on the speaker and increase the volume with the Volume Key.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
Goto Control Panel
Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
In device Volume Click Advance
Master Volume Control Window will open
Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
Dear. chek that if ur speaker volume is decrease and make sure ur speaker volume is full.And if ur speaker volume is full and spkeaker is not responding then u have to go to a certified mobile fone repairer to change ur speaker.U can also change ur speaker urself its v easy...thanks
i would recommend you ask logitech if they can fix it, if the cost is too high i would go look for other stores that fix speakers, if it still cant be fixed, your better off buying new ones because having speakers like those for 5 years is a long time, it may just be time to change
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
