Intel 845GE Motherboard Logo
Posted on Jan 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver for mainboard
Hello
I need a driver for the mainboard. For the LAN-port 1394
Anonymous
Level 2:
Scholar:
  • Expert 58 Answers
  • Posted on Jan 06, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
58
Questions
0
Helped
70474
Points
151
Here is the Link for the Intel Support Side for this Chipset:
845GE is only the chipset from the mainboard.
When you need the link for the driver for an special mainboard we need the mainboard model Number:
http://www.intel.com/products/chipsets/845GE/
driver for mainboard - spacer.gif Intel® 845GE Chipset spacer.gif driver for mainboard - tabline.gif"/uploads/images/tabline.gif" alt="tabline.gif" class="h_mi" /> tabline.gif tablidriver for mainboard - tab_where.gif= tab_solutions.gif tab_where.gif driver for mainboard - spacer.gif tabline.gif spacer.gif spacer.gif 845ge_chipset_sm.jpgThe Intel® 845GE chipset is optimized for the Intel® Pentium® 4 processor supporting Hyper-Threading (HT) Technology†. Highlights include DDR333 memory and Intel® Extreme Graphics technology, running at 266 MHz core speed, which enables even better performance than previous generation chipsets.
Download Driver Lan
Hello visit the manufactures site of the pc, or the mainboard manufactures site, in search for the lan driver.
Try enter the pc brand or mainboard number in google seach.
This is sometimes most helpfull.
Try to avoid the pages where you have to pay for the driver.
The manufactures page is always free.
Good luck
1helpful
Network driver AM37
Hello here is the fic download page:
http://www.fic.com.tw/download/motherboards.aspx
The model of your mainboard is not to be found here.
But the mainboard was fitted in this pc here:
http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1427
Try to download the LAN driver, but please unzip the file before you install.
If the driver is not working, visit the PC homepage (not the mainboard) for downloading the driver.
Best of luck
1helpful
SiS LAN DRIVER
Hello i need the brand of the mainboard, to find the driver for you.
Or visit the pc`s homepage, or the mainboards homepage.
Kd7a drivers for windovs7/vista
Hello try the homepage:
http://abit.ws/page/en/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Or the intel download site:
http://downloadcenter.intel.com/
And run the update utility.
Features
Processor
Supports AMD-K7 Athlon/ AthlonXP/ Barton FSB 200/266/333MHz Processors
Chipset
- VIA KT400A / VT8235CE chipset
- Supports Hi-Speed Universal Serial Bus (USB 2.0)
- Supports Advanced Configuration and Power Management Interface (ACPI)
- Accelerated Graphics Port connector supports AGP 8X /4X (0.8V /1.5V)
Memory
- Three 184-pin DIMM sockets
- Supports 2 DIMM Un-buffered DDR 333/400 (Max. 2GB)
- Supports 3 DIMM Un-buffered DDR 200/266 (Max. 3GB)
LAN
- On board 10/100M LAN
Audio
- 6-Channel AC 97 CODEC on board
- Professional digital audio interface supports optical S/P DIF Out.
You can`t use xp drivers for windows 7, it does not work that way.
This mainboard is from the year 2002, and you probably can`t find any drivers for windows 7.
The mainboard is too old, for the windows system.
Continue using windows xp, or buy a new mainboard or pc.
Good luck
Drivers
Hello your mainboard must have a model number printed in.
You can install this free software to find detailed info:
http://www.piriform.com/speccy
Save the installation file on a usb drive and install it on your pc.
When you find the mainboard number use google search in seach for the drivers.
The INTEL support site can sometimes be helpfull:
Reply me back if you can`t find the driver.
But i need all the info about the mainboard to find the drivers for you.
I also need to know what windows system you are useing.
Good luck
Unable to LAN in windows xp
Hello download here:
http://www.mercury-pc.com/download/uploaded/drivers/
Any file from here needs to be unziped before you install.
You have to know what mainboard number you have.Then seach for the driver.
Its maybe the realtek lan driver but i am not sure.
Because you have not written the mainboard number.
The mercury download site:
http://www.mercury-pc.com/downloads.php
Is here but you can`t download anything i don`t know why.
Good luck
1helpful
NETWORK Card don't appear on the Network Adapter on board P5L-VM 1394
Hi, you can download the drivers here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5LVM_1394/#download
Please select your windows version.
Select the lan driver and click on global for download.
Unzip the file before installation.
You may also need the driver for the chipset.
Update the other drivers if some missing.
How do i reinstall my 1394 sys driver ? not on this computor on my wife's
http://www.soft32.com/download_170557.html
here you will find a 1394 net adapter ...which is a driver for ethernet adapter (Lan) if you were talking about IEEE 1394...for fire wire ...this might be different
Lan port not working , tried all normal options
try to re-install you network driver.
go to control panel, system maintenance, device manager. uninstall the previous driver downloaded on your machine then boot up machine. once done, install your network driver.
No LAN conection displayed in network connections
check that proper driver is installed, in the device manager that shows excmlatory mark that indicates proper driver not been installed, update the driver it will works
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
